Saw lots of videos on these with error code B200. Cleaning the head seems to solve it many times.
So after I put the cleaned out printhead back in, I did the trick again
where u power it off when the carraige is half way to the left, remove power
andapply power.
This time, it said "processing" on the screen, and the carriage did alot of
extra maneuvers, and looked like it was attempting a cleaning cycle.
At the end, the screen said "cover open", and the carriage slid toward the
left,stopped, and (3) cartridge LED's were flashing slowly, which I was told
meansthose cartriges are low ink. If I closed the cover, the B200 error would
eventually come back.
I asked the customer if he had spare cartridges, and he did, so he bought
them over, we put them in , tried again, and same B200 error.
I told him its likely a print head, and he may try ordering one thru ebay or
something to give that a try. Apparently there are microelectronics inside these
heads? Beats me how they control or regulate ink flow. On the back of the head there are about
50 contact pads, which I guess must be sensors of some kind? He did say he took the head out
at one point, and perhaps ESD may have damaged some sensitive circuitry in
there, and now the head is out of spec.
I thought I saw some russian videos jumpering some of the pads on the head to bypass the code....anyone have any success?
Szevasztok! Baratom Canon PC-D 450-es gepe kerult hozzam E007-es hibakoddal.A kemenceben a film volt elhasznalodva (teflonreteg serult).Film es nyomohenger csere utan is ugyan az a hibakod.Tud valaki egy szerviz konyvvel vagy legalabb egy hibakod tablazattal segiteni vagy egy ottlettel hogy mi okozhatja a hibat? Futo ellenallas aramkore folytonassagot mutat,futoszal+hobiztositek jok nagy valoszinuseggel. Segitsegeteket elorre is koszonom,Kallos Peter
A fenti nyomtató tápjának kapcsolási rajzát keresem, vagy kapható e táp külön.
Tisztelt uraim!
Segítséget kérnék!
A fenti nyomtató előző nap kifogástalanul működött. Másnap a hálózati kábel csatlakoztatása után, bekapcsolni sem lehetett.( A hálózati zsinór jó!) A tápot kivéve, asztalon a kimeneten csak 10 V és 7.5 V körüli érték mérhető.
Elkók jók ESR.- re és kapacitásra is. A csatlakozó egyik érintkezője két tranzisztoron egy optocsatolóra megy mely a primer oldalt szabályozza. Van e ennek köze ahhoz, hogy nincs meg a teljes tápfeszültség kiemelt táp esetén? Esetleg hol kéne kutakodni? A készülékből kivett tápnak a kimenetén meg kéne lenni a normál tápfesznek? A feszültségeknek 32 V és 24 V.- nak kellene lenniük.
Kérem aki jártas ebben legyen szíves segítsen!
Előre is köszönöm!
Galibali
