Samsung Ue37c5000 készülék ma kikapcsolás után többet nem kapcsol be csak a power led villog.
Ezt megelőzően csináltam a service menüben egy factory resetet, mert valamiért nem tudtam a mindig tv-t beprogramozni és gondoltam hátha el van állítva valami.
Nem tudom van e összefüggés, mert ezután még ment a tv és ki-be is volt kapcsolva, aztán egyszer csak már nem kapcsolt be többet.
Tudna valaki segíteni?
Tamás
Mark:NEO LED-2202FHD
Model:LED-2202FHD
Chassis (main board, components): 17MB60-3 flash 25Q80
LCD Screen/Panel :: LC215EUN (SC) (A1)
More informations: Power supply 17PW05-2
_SN : 6694377 100624
It does not work, the front LED off, the power supply is ok.It was software on usb several times, periodically every 2-3 months and it worked, finally it was left with the st.by LED off, that's why I-m thought about flash memory. Thanks a lot!
have a toshiba TV 32EL933G , the Power LED turns green but the TV does not give anything . the power supply in the secondary has no tensions , is not to boot. power supply is PE-3850-01UN-LF does not swing to start the secondary :(
Hi all,
i want to repair a power board : BEKO XLA194-03.
T2001 ( MOSFET P9NK70ZFP ) is devinitively defective.
See pic. 1
i downloaded this manual: https://elektrotanya.com/beko_xla194-03_power.pdf/download.html
but the repair list ( https://elektrotanya.com/files/forum/2014/08/Beko%20XLA194-03%20PSU%20repair%20kit.txt) does not correspond to the link above.
The names of the elements are completely different.
But the names of elements from my board are the same like the manual ( link above).
Knows someone which elements I must exchange, related to schematics in the manual?
Best regards Dietmar
