alaphiba: nem megy a táp. 33uF kondicsere, indul, de a kép teteje visszagyűrődve. Kondicsere ott is, megjavul, de nincs OSD. "Vakon" elindítottam a hangolást, végig is söpör szépen de nem tárol adót és nem áll meg, csak pörög mint a fúrótokmány. 24C04-et cseréltem, helyzet nem változott. Procit kéne cserélni? Nincs OSD, nincs AFC....
Sziasztok. Elkellene egy kis segitség a kollégáktól mivel ma egész nap szenvedek a fent emlitett tv-el. A tv-t azzal a hibával hozták hogy nem indul. Egy kis méregetés és megvan a hiba, a sorvégfok (J6920A). A csere után ahogy bekapcsolom a tv-t, újból elszáll a tranyó. Én a sorkimenőre gyanitok. Volt-e valakinek ezzel a tv-el ilyen gondja??
A segitséget előre is köszönöm
Hi, my SAMSUNG UE40D5000 tv doesn' t work anymore. The red led light indicating that the tv is plugged is not powered when I plug in the tv. The original power board modem is BN44-00473B. I have checked the voltage on the connector to the mother board of the tv, and it was 0 instead of 5.3V or 13V on the different pins, with the fuse still working and no obvious overheated part on the power board and no bulging capacitor seen neither.
I have then changed the power board with a used one bought on ebay, which model BN44-00473A is said to be compatible. It has then worked perfectly 2 days until yesterday. This morning I had to move a little bit the tv, what I did very gently, and got really disappointed as I plugged it and didn't see the red led light on anymore.
Since this morning, the power board seems to be broken once more ( I have moved from my original flat 1 week ago and don't have a multimeter to check once more that the fuse is ok and what are the voltage on the connector to the mother board )
I am wondering if this new power board failure is just bad luck, 2 days after receiving this other power board circuit ( that is a used unit, not brand new) or if the mother board could have damaged it. In the first case I would send the power board back to the seller, otherwise I will probably give up as I don't have time and skills to repair the tv.
My question is : do you think the mother board or another unit connected to it, can damage the power board ?
Thanks for your help and answers !
Samsung CW-29M026P típusú tv nem kapcsol be.A relé ki be kapcsol,a led világít és villog felváltva.Nagyfeszültség nincs egy pillanatra sem.A sorvégfok nincs elszállva(2sj6920),volt egy új azt is beletettem de azzal sem megy nem az a probléma szerintem.Minden táp megvan,kivéve a 135volton,170-et mérek ez valamilyen hibára utal de tovább nem jutok.Örülnék egy kis segítségnek.
Előre is köszönöm:FLY001
