Has anyone ever had success removing the hard glossy type of compound used to seal
various kinds of electronics ou there in the trade?
I am trying to get at the bobbin and diodes inside a small HV (FBT) transformer
to study the material used in construction.
I have heard there is a solution it can be soaked in that dissolves only the potting, and
leaves other material undamaged, but I dont know if its merely acetone or something else.
I tried baking in the oven a while, and it didnt seem to make the epoxied area weaker and when I tried pulling
on the pins, the pins came out.
Hoztak egy redőnymotort, hogy nézzek rá. 5-6 fel-le járatás után (3 másodpercig forog egy irányba) a motor épp csak fogható kézzel. 110W van ráírva, 0,53A-t, 122W-ot mértem. Mindezt az asztalon, terhelés nélkül. Szabad ennek ennyire melegednie?
Jácint
