ABC RU-161BATTERY OR AC RECEIVER SCH.
61.3 KB
Looking for similar abc manual?
ABC RU-161BATTERY OR AC RECEIVER SCH. service manual (1st page)
Preview of ABC RU-161BATTERY OR AC RECEIVER SCH. [1st page]
    ABC OR AC RECEIVER SCH. RU 161 BATTERY 161BATTERY
Pioneer A80 tönkreteszi a magass sugárzókat
Sziasztok szép napot kívánok. Segítségeteket szeretném kérni,olyan problémával találkoztam ami némi fejtörést okoz.Van nálam egy Pioneer A80 150W full tranzisztoros erősítő.Olyan panasszal, hogy mindkét oldala kinyírja a magas sugárzókat.A feszültségeket leellenőriztem minden megfelel a kapcsolási rajzban leirtakéval. Már javítottam ilyen erősítőt más jellegű hibával.Ilyen hibával nem találkoztam még Üdv mindenkinek
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
LG SPN5B-W SUBWOOFER nem működik, stby sincs...
Adott ez a Soundbar vezeték nélküli mélynyomó része, nem akar működni, semmi életjel,készenlét sem világít/villog rajta. EBR89625801 táppal egybeépített alaplap van benne, mérésre tápfeszültségek rendben, táp részen, és az alaplapi DC-DC konverteren is. Erős a gyanúm, hogy az alaplapi SPI Flash memória lehet a hiba oka, WIC602: MX25L8035E a típusa, ehhez keresnék tartalmat.
A jel útjában lévő elektrolit kondenzátorok cseréje Technics SU-A700mk2 erősítőben (megoldva)
Sziasztok! Egy pár elektrolit kondi szeretnék kicserélni elektrolitra vagy fóliakondenzátorokra. Az értékek 3,3uF 50V ill 4,7uF 50V. Én a WIMA kondikat néztem ki, de olyan sokfélét gyártanak (MKP, MKP4, MKP10, MKH, MKS2, MKS4) hogy annyira nincs tapasztalatom velük kapcsolatban. Valaki tudna ebben segíteni? Esetleg másféle típusú kondenzátor? Megoldás: Az egyik helyen Jantzen MKP 3,3uF 400V fóliakondenzátor + K40Y-9 10nF 630V orosz papír-olaj kondenzátor A másik helyen pedig 4,7uF 50V Panasonic Pureism elektrolit kondenzátor + K72P-6 10nF 200V orosz teflonkondenzátor Köszi, Karcsi
