Keresek ACER AL1718A monitorhoz flash tartalmat.
Sajnos ilyen mentésem nincs, az AL1716, AL1717 tartalmakkal el sem indul.
Súlyos táphiba miatt az órajel, a képhelyzetek nem állíthatóak be illetve pld. a függ. képhelyzet 100% fixen, 2 cm eltolással.
Egyéb flash tartalmakat bepróbálva ezen paraméterek beállnak, de ha pld nincs menü, akkor hiába, használhatatlanok.
Saját bin állományt többször visszaírva látszólag jó az első újraindításig.
Valakinek mentése esetleg?
Üdv: Sándor
Hi,
I'm sorry for writing in English, but I don't understand any single word in Hungarian and I couldn't find an English subforum there.
I have changed the LVDS controller and now it's working perfectly, but I need help with the backlight. The CCFL lamps in the screen are OK. I connected the screen to another inverter (from BenQ T705, made on TL1451 which also has "protect" function) and the backlight worked perfectly. Again, I connected other screen to the malfunctioning ILPI-075 inverter and the screen also goes blank.
I changed all THT electrolytic capacitors on the board, but not much has changed. Before, the backlight was turning off almost immediately, now it glows for 1-2 seconds and then turns off.
The HV side of inverter transformers is about 470 ohm, they look OK.
I measured random capacitor in the +16V line, which is supplying the high voltage inverters.
We can see how the voltage went down while the backlight was powered on.
Also, the ON/OFF signal on ICL837's pin 8 is always present after powering up the power supply, even after the backlight turns off.
I don't have any idea what to check now..
Kérdezném,hogy van-e valakinek Acer al1715sm lcd monitorhoz vezérlőpanelje?
Kedves kollégák!
Valószínűleg Flash vagy eprom hibás a kicsike. A kijelző teszt üzem módban van a végtelenségig(szinek váltogatása). Ehhez keresnék tartalmat.
Elvileg a szokásos orosz aranybánya oldalon van hozzá.
https://remont-aud.net/dump/mnt/acer_gd245hq_shassi_main_board_48_7d701_021/12-1-0-43688
Sajnos én ide nem tudok bejelentkezni(teszt kitöltést nem tudom értelem szerűen lefordítani). Ha meg tenné valaki,hogy letölti.Nagy lenne az öröm!!!
üdv.
