ADCOM GFA-4702 SM
336.1 KB
Looking for similar adcom manual?
ADCOM GFA-4702 SM service manual (1st page)
Preview of ADCOM GFA-4702 SM [1st page]
ADCOM GFA-4702 SM service manual (2nd page)
Preview of ADCOM GFA-4702 SM [2nd page]
    ADCOM GFA-4702 GFA4702 GFA 4702
FET
Üdv MESTEREK!Keresem a TP50N20P FET-t. Elvileg 50A 200V. Ez egy böhöm autó erősítöbe van.Hol kapható és mivel pótolható? Tok :TO220 .Köszönöm és köszönném.Öreg T
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Aiwa AV-NW-30EZ Házimozi erősítő
Sziasztok Kedves kollégák! A fenti erősítőhöz keresnék kapcsolási rajzot, a fégfokba szét égett egy két alkatrész, és ezeket kellene beazonosítani. Köszönöm előre is!! Csaba
Panasonic sa-ak320 dioda beazonositása(Megoldva)
Hali.Kis segitséget kérnék egy dioda azonositásban a pozició szám:d509 zárlatos lett,s f61 hibakódot ir ki.A diodán amenyire kiolvastam b10 vagy valami ilyesmit ir(nem biztos).Sm et vettem le a netröl de nem egyezik vele.Ha valaki tudja kérem segitsen Üdv
