AERODYNE 54
1.6 MB
Looking for similar aerodyne manual?
AERODYNE 54 service manual (1st page)
Preview of AERODYNE 54 [1st page]
AERODYNE 54 service manual (2nd page)
Preview of AERODYNE 54 [2nd page]
    AERODYNE 54
TECHNICS SU-V4X SAFETY MÓDBAN KAPCSOL BE!
Sziasztok! Szertném kérdezni a fenti erősítő bekapcs után a védelmi led villog, a relé nem húz meg, SAFETY OOERATION villog. Ezt egy jól működő állapot után produkálta, csak úgy hirtelen egy másnapi bekapcskor. Mit nézzek meg, merre kezdjem keresni a hibát? Előre is köszönöm válaszotokat!
Javítsd a címet!
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Lemezjátszó előerősítő építéséhez kérek segítséget
Sziasztok. Egy lemezjátszóhoz szeretnék építeni egy előerősítőt. Azt tudni kell hogy, a lemezjátszóban egy kristály betétes hangszedő dolgozik. NE5532 ic nem vált be túl halk. Találtam riaa korrektor rajzokat de a lemezjátszó így is halkan szól. Kérdésem az lenne hogy milyen előerősítőt építsek? Ha tudnátok segiteni akár egy rajzal vagy valami infoval annak nagyon örülnék. Van egy pár lemezem és meghalgatnám őket. Köszönöm.
HiFI kenwood, letöltő oldal, fizetős?
Üdv Mesterek! Egy kenwood HiFi került hozzám,kerestem hozzá a szerviz manuált és erre az oldalra tévedtem.: http://www.hifi-manuals.com/Kenwood/page-13 Kérdésem , ismeri valaki ezt azz oldalt? Letölteni csak úgy lehet ha regisztrálok. Ingyenes, vagy fizetős oldal, ha fizetős mennyi? Köszönöm, minden infó érdekel Üdv. hajkar
