Hello to everyone, I hope someone can help me in English :D
i have a problem with this LCD TV Akai AZ 4280FHDT4 LCD 42" .
It's power supply was fault, and I got it working, but now i have another problem, there is no picture. Actually the screen is fade white-blueish, no picture no OSD, but SOUND is working fine...
I can't find service manual for this TV anywhere... And that is even more difficult because I cant see what is the main processor and the main IC on T-Con Board, because there is a glued cooler over them.
The main board is:20-MT5362--13-OX
The card that controls the LCD screen: SZTHTFTV1607
Power supply: MLT198TL
I suspect the T-CON board, because i get 12V from main board going too it, but there is no supply for main processor on TCON (probably MST6xxx IC), there should be 3.3v to supply it, but there is not... there is i thin a DC to DC convertor that should convert 12 to 3,3 but i cant read any marks from it, so i don\t know what it does exactly.
Here is what the board is, i think, it has its cooler taken off...
http://download.szlva.com/QQ/ep/EP00041200118.pdf
Here are the pictures of the tv set adn individual modules
http://i50.tinypic.com/ifuc6g.jpg
Behind
http://i46.tinypic.com/2csf5mf.jpg
Main Board (20-MT5362--13-OX)
http://i50.tinypic.com/259wsok.jpg
Power supply (MLT198TL)
http://i46.tinypic.com/f2kkkx.jpg
Others
PNEL - T805A
http://i48.tinypic.com/rb9xer.jpg
AV/HDMI/USB modul
http://i45.tinypic.com/eddg1.jpg
SZTHTFTV1607
http://i50.tinypic.com/2m65n2s.jpg
Remote
http://i45.tinypic.com/2e4dlcl.jpg
If anyone knows where can the service manual can be found it would be nice...
I see that many LCD tv's have similar problems, and that the LCD driver is mostly the reason...
Is there any similar manufacturer, that could help too...
Thank you in advance
Sziasztok. Akai tévét javÍtok és segÍtséget kérnék tölletek. A tévé késszenléti piros ledje nem világÍtott forrasztási hiba miatt. Átforrasztottam a nyákot most már világÍt a led de a tévé nem indul. C68230Y processzor a tápfeszt megkapja de nem indÍtja a tévét. Egy relét kéne kapcsolnia ami a tévét indÍtja. Ha a relét megpatkolom a tévé beindul de semmire nem reagáll se gombokra se a távra. Lehetséges hogy processzor hibás?
Üdv. mindenkinek!
AKAI ATX-RF2165 tipusú T2P03 (00)taurasnak kinéző alaplappal szerelt TV hez elsősorban epromot illetve rajzot vagy egyáltalán beazonosítást.
Proci:TDA9351PS/N3/2/1933
Függő IC:STV9302B
Memória:24C06
Hahg IC:TDA 7056B
+ egy CD4053
Nagyon kellene valami segítség mert több darab áll memória hiba miatt .
A hiba jelensége ha a TV t bekapcsolom egyből a szervízmenü jön elő
Sajnos nem müködik a távvezérlés. Az adóval nincs gond, telefonon látszik hogy müködik, amugy van 1régi törött is meg 1ujabb, mindkettövel probáltam.de nem csinál semmit. Előlapi gombokról minden műkxik jól, jelenleg tvbozozon keresztül használom (SCART csatlakozon) annak a távirányitójával, de kellene a sajátja mivel elég sokszor nézek olyan adást ahol 4:3 képarány van, és hiába van a TV Auto beállitáson, 16:9 arányt érzékel és így a kép tulságosan össze van nyomva, élvezhetetlen az adás. A saját távirányitoval csak 1gombnyomás lenne javitani a képet!
Kicseréltem az IC502-est ami egy TSOP 1736, de sajnos semmi változás . . .
Saszé: 11AK30 A11, mivel nagyobb mint 3Mb ezért tömöritettem.
Bármi ötlet jól jönne! Előre is köszönom.
