Tisztelt kollégák segítséget szeretnék kérni. Van egy AKAI CT-2107DT tv készülékem, de az a bajom,hogy rettenetesen halkan szól valamelyik csatornán nem is lehet a hangját hallani.A képernyőn látható,hogy a visszajelző csík megy rendesen oda vissza. A többi funkció rendesen szabályozható.Tisztelettel javítási tippet szeretnék kérni. Előre is köszönöm.
Hello to everyone, I hope someone can help me in English :D
i have a problem with this LCD TV Akai AZ 4280FHDT4 LCD 42" .
It's power supply was fault, and I got it working, but now i have another problem, there is no picture. Actually the screen is fade white-blueish, no picture no OSD, but SOUND is working fine...
I can't find service manual for this TV anywhere... And that is even more difficult because I cant see what is the main processor and the main IC on T-Con Board, because there is a glued cooler over them.
The main board is:20-MT5362--13-OX
The card that controls the LCD screen: SZTHTFTV1607
Power supply: MLT198TL
I suspect the T-CON board, because i get 12V from main board going too it, but there is no supply for main processor on TCON (probably MST6xxx IC), there should be 3.3v to supply it, but there is not... there is i thin a DC to DC convertor that should convert 12 to 3,3 but i cant read any marks from it, so i don\t know what it does exactly.
Here is what the board is, i think, it has its cooler taken off...
http://download.szlva.com/QQ/ep/EP00041200118.pdf
Here are the pictures of the tv set adn individual modules
http://i50.tinypic.com/ifuc6g.jpg
Behind
http://i46.tinypic.com/2csf5mf.jpg
Main Board (20-MT5362--13-OX)
http://i50.tinypic.com/259wsok.jpg
Power supply (MLT198TL)
http://i46.tinypic.com/f2kkkx.jpg
Others
PNEL - T805A
http://i48.tinypic.com/rb9xer.jpg
AV/HDMI/USB modul
http://i45.tinypic.com/eddg1.jpg
SZTHTFTV1607
http://i50.tinypic.com/2m65n2s.jpg
Remote
http://i45.tinypic.com/2e4dlcl.jpg
If anyone knows where can the service manual can be found it would be nice...
I see that many LCD tv's have similar problems, and that the LCD driver is mostly the reason...
Is there any similar manufacturer, that could help too...
Thank you in advance
Javított már valaki ilyet? Semmit nem találok róla. Az alaplap CV9202H-T. Ha stby-ról elindítom átvált zöldre a LED és minimális háttérfény dereng, viszont semmi más, kikapcsolni se lehet csak áramtalanítással.
2 stab IC kimenetén 3,3 és 1,6 V-ot mérek.
Sziasztok! :)
Ismét a segítségeteket kérem! :help:
A címbeli készülék tápegysége kapott egy nagy lórugást a hálózatból, aminek hatására jónéhány alkatrész elszenesedett, a táp IC pedig ledobta a kalapját (és persze nincs is meg). Az IC-ről csak annyit tudtam megállapítani, hogy 8 lábú DIP tokban volt. :(
Rajz kellene, vagy legalább a táp IC típusa. :hmmm:
A készülék IC garnituráját meg tudom adni (a táp kivételével):
TDA 9886T UOC
STV 8216 audió proc
STV 8175S függőleges végfok
CD 4053B analóg kapcsoló
A táp csopper FET: W10NK802
