Hello to everyone, I hope someone can help me in English :D
i have a problem with this LCD TV Akai AZ 4280FHDT4 LCD 42" .
It's power supply was fault, and I got it working, but now i have another problem, there is no picture. Actually the screen is fade white-blueish, no picture no OSD, but SOUND is working fine...
I can't find service manual for this TV anywhere... And that is even more difficult because I cant see what is the main processor and the main IC on T-Con Board, because there is a glued cooler over them.
The main board is:20-MT5362--13-OX
The card that controls the LCD screen: SZTHTFTV1607
Power supply: MLT198TL
I suspect the T-CON board, because i get 12V from main board going too it, but there is no supply for main processor on TCON (probably MST6xxx IC), there should be 3.3v to supply it, but there is not... there is i thin a DC to DC convertor that should convert 12 to 3,3 but i cant read any marks from it, so i don\t know what it does exactly.
Here is what the board is, i think, it has its cooler taken off...
http://download.szlva.com/QQ/ep/EP00041200118.pdf
Here are the pictures of the tv set adn individual modules
http://i50.tinypic.com/ifuc6g.jpg
Behind
http://i46.tinypic.com/2csf5mf.jpg
Main Board (20-MT5362--13-OX)
http://i50.tinypic.com/259wsok.jpg
Power supply (MLT198TL)
http://i46.tinypic.com/f2kkkx.jpg
Others
PNEL - T805A
http://i48.tinypic.com/rb9xer.jpg
AV/HDMI/USB modul
http://i45.tinypic.com/eddg1.jpg
SZTHTFTV1607
http://i50.tinypic.com/2m65n2s.jpg
Remote
http://i45.tinypic.com/2e4dlcl.jpg
If anyone knows where can the service manual can be found it would be nice...
I see that many LCD tv's have similar problems, and that the LCD driver is mostly the reason...
Is there any similar manufacturer, that could help too...
Thank you in advance
Szép napot mindenkinek!
Tárgyban szereplő tv-vel szívok. Azzal hozták,hogy készenlét van de nem lehet bekapcsolni.
Már belehet kapcsolni hang is kép is van de a függ.kontúrok cakkosak és ha a G2-t túl világosra veszem akkor
leáll a függ.eltérítés,átmegy vizszintes csíkba.
Lehet,hogy az AN5534 csinál ilyet?Sajnos nincs ilyenem, nem tudtam próba cserét csinálni.
Hátha mégsem az,akkor nem rendelném(nem az ára sok hanem a szállitása).
Köszönöm:Géza
Sziasztok. Akai tévét javÍtok és segÍtséget kérnék tölletek. A tévé késszenléti piros ledje nem világÍtott forrasztási hiba miatt. Átforrasztottam a nyákot most már világÍt a led de a tévé nem indul. C68230Y processzor a tápfeszt megkapja de nem indÍtja a tévét. Egy relét kéne kapcsolnia ami a tévét indÍtja. Ha a relét megpatkolom a tévé beindul de semmire nem reagáll se gombokra se a távra. Lehetséges hogy processzor hibás?
Sziasztok Mester Urak!
A fent említett készülékkel gyűllt meg a bajom.A sortáp kondi megadta magát.Átkondiztam,Működik. DE! A program léptetése nem jó.Sem a távszabról sem az előlapról.Ha a program számát ütöm be működik ha léptetnék 1-es programra lép és onnan sehova.
A többi funkció rendben./Lehet, hogy áthúzott és kapott a proci?/
Köszi a segítséget
Üdv pluto63
