Hello, I got a problem with my Sony Receiver STR-DE 225.
There´s a sudden interruption of Audio in non defined intervalls - may be once ore 6 times during appr. 5hrs operation.
Interruption does not depend on Volume. Connection cables and speakers I´ve checked.
There´s a loud crack in both speakers, display shows for short time "PROTECTION".
After switching off and on again, everything operates normal until next interruption.
I removed from the inside of the receiver a lot of dust with a vacuum cleaner, but this didn´t help.
Unfortunately Sony has no documents for this device, as it is To "old" (1996), or could give me a hint,
in what cases "PROTECTION" might appear.
Is there anyone to give me a clue? Thanks
Sziasztok! :)
Egy Hollandiában dolgozó ismerősöm számára keresek audio áramkörökben használható elektroncsöveket.
Kérlek benneteket, hogy küldjetek címeket és elérhetőségeket (minél többet), ahol ilyeneket lehet vásárolni (akár nagyobb tételben is).
Fülesmester
Hi
I'm looking for a schematic diagram for this equipment:
Professional Power Amplifier XA-1000
The main fuse was blown and according the owner it blowns again after replacement.
He used a 40 amp fuse. The original fuse is not around anymore and there is nothing written outside on the label. So it's somewhat a lottery about the correct fuse rating.
Anyway, I would like to repair this equipment but without a diagram it would be a pain and nearly impossible.
Tryed to find a diagramwith Google search - negative. Also the manufacurer ist unknown this days.
Maybe a reader has more information aboutb this.
Thanks a lot
Redwood (74)
https://www.simplysoundandlighting.co.uk/bst-xa1000-1000w-power-amplifier
Üdv Mindenki!
Van egy (ráadásul) saját végfokom.
Bekapcsoláskor kiül pozitív dupla tápfeszre (mivel H osztályú) utána beáll 0V a kimenet, de ez idő alatt a védelem megfogja és megáll. Az összes FET (IRF) illetve tranzisztor (MJ) jó benne.
Ha kiveszem a kapcsoló FET-eket akkor is megcsinálja ugyan ezt (!).
Ha a védelmet leakasztom indításra, majd vissza akkor utána tökéletesen "muzsikál".
Valakinek valami tipp?
A rajz itt is fent van.
üdv.
Mihi
