Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Szisztok!
Bauknecht wa plus 622 slim sokáig mos. Valamiért folyamatosan "lefagy". Az idő jelzőn látható hogy ilyenkor nem villog a kettőspont az óra és perc között. Ilyenkor a fűtést is lekapcsolja. 10mp múlva újra indul a fűtés és a motor is kezdene hajtani, de újra megáll. Fűtőszál nem testzárlatos.
Szerintetek?
Üdv. G.
Tisztelt kollégák. Segítséget szeretnék kérni a BIR4DP8FS3PT , 855653601100 sütő javításában.Be kapcsoláskor az óra és a sütési program beállítása és indítása után semmi nem történik, kb fél perc után adja a f03 hibakódot.Hibakód megjelenése után nem reagál semmire. Áramtalanítás után újból lehet állítani mindent. A tulajdonos azt mondta mikor megvették ezzel a hibával javították és akkor termisztort cseréltek benne.A termisztort kivettem 1Kohm az ellenállása kb 20fokon, ha melegítem fokozatosan növekszik.Sajnos ennek az értékét sehol nem találtam meg, és szerviz programos sem.
Köszönöm a segítségeket.
Tisztelettel.
Ferenc
Üdv. mindenkinek, sziasztok!
Szemezgetek a tárgybéli mosógép márkával és típussal (vagy hasonlóval).
Ismeri valaki javítás, üzemeltetés oldalról?
Tudom, Whirlpool csoport talán jobb minőségű gépe.
Miért csak outletekben, szépséghibás boltokban lehet kapni mo.-on?
Látszólag azonos vagy hasonló - csak felültöltős érdekel a hely miatt - gépek között mi lehet a különbség? 6,0 - 6,5 - 7,0 kg????
Csak kefe nélküli (ZEN) motorost szeretnék venni.
Kérlek, mondjátok el a véleményeteket, érdemes venni a Bauknecht "gyártmányból", vagy felejtős.
További szép napot!
Üdv: Sándor
Miért itt beszélgetsz? Arra a kocsma van kiszemelve! Egy csöppet felfüggesztem!
