Üdv. mindenkinek, sziasztok!
Szemezgetek a tárgybéli mosógép márkával és típussal (vagy hasonlóval).
Ismeri valaki javítás, üzemeltetés oldalról?
Tudom, Whirlpool csoport talán jobb minőségű gépe.
Miért csak outletekben, szépséghibás boltokban lehet kapni mo.-on?
Látszólag azonos vagy hasonló - csak felültöltős érdekel a hely miatt - gépek között mi lehet a különbség? 6,0 - 6,5 - 7,0 kg????
Csak kefe nélküli (ZEN) motorost szeretnék venni.
Kérlek, mondjátok el a véleményeteket, érdemes venni a Bauknecht "gyártmányból", vagy felejtős.
További szép napot!
Üdv: Sándor
Miért itt beszélgetsz? Arra a kocsma van kiszemelve! Egy csöppet felfüggesztem!
Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Sziasztok .Segítséget kérnék a mosógép javításához. Hiba jelenség, a mosás rendben elindul,ajtó lezár felveszi a vizet elindul a forgatás bekapcsol a fűtés majd a 9-10 perc mosás után kiáll f01 hibára.A mosógép bauknecht 7 kg EW7F4 tip. Minden programon ugyan az a jelenség.Amit eddig cseréltem motort ,elektronikában a motor triacot,és fűtőszálat.A fűtőszál csere után egy program (1 órás) végigment,de a következő mosásnál újból visszajött a hiba.Már nem tudom hogy mit csináljak még vele .köszönöm a segítséget
Némi megerősítés kéne,javítok egy Bauknecht_GCFP_4824_WH mosogatót fűtés hibával.
Az NTC szakadt ez biztos.
Találtam is egy hasonló whirlpoolba való holmit.
Orczyban
MHS709
Hőérzékelő (NTC) WHIRLPOOL mosogatógép
Viszont elég drága ahoz hogy berendeljem,aztán ha mégsem jó ..
Szóval kinézetre passzol, de a szervíz manual sem írja az értékét és itt sem szerepel a terméklapon.
Tehát a kérdés jó e vagy sem bele?
Esetleg bontott valakinél?
