Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Üdv Mindenkinek!
Ismét kérnék egy kis segítséget vagy ötletet. Hozzám került ez a szárítógép fűtés problémával.
A termosztát volt hibás a fűtéselemben, kicserélve továbbra sem melegít. Azaz, hogy elindul a fűtés
egy 10 mp-re utána megáll. A programok lemennek rendesen de fűtés nincs. A fűtőelemben található egy hőfokszabályozó
ezt mérve jól működik, valamint a termosztát és 2 db hőbiztosíték. Mind jók.
Ha gép programválasztó kapcsolója "0" állapotban van a start gomb akkor is villog, azonban megnyomva "meleg légcsatorna hibát" jelez.
Ha programot indítok elindul, de a fent említett folyamat van: fűtés megy 10 mp utána leáll, de a program megy tovább rendesen.
A következőket végeztem:
-a fűtőelem hőérzékelője 18 Kohm melegitésre csökken
- a légcsatorna hőérzékelőt ellenőriztem - szépen dolgozik 12 Kohm 20 fokon, melegítve csökken- dolgozik.
-a dobban a maradék nedvesség érzékelő ki lett takarítva, kontaktok rendben,
-minden érzékelőt lát az elektronika - leellenőrizve
-az elektronika hibajelzés törlést többször is elvégeztem nem vezetett eredményre
-a gép tiszta, nincs lerohadva szivattyú rendben (bár ennek úgy gondolom sok köze nincs a hibához)
Véleményem szerint a hibajelzés tiltja a fűtést.
Elektronika hibára, konkrétan Eprom hibára tudok már csak gondolni.
Valaki tapasztalt már hasonlót, minden segítséget köszönök.
Bauknecht TK Care 6B a típusa.
Üdv Tamás
A fent nevezett szárítógéppel lenne problémám. A gép ékszíj problémás volt, az ex tulaj cserélte/cseréltette a szíjat. A gép eszméletlen hangos volt mikor elhoztam, és nem fűtött. A dob nem volt rendesen felhelyezve a tartó görgőkre, ezért volt hangos, ezt megigazítottam. A fűtéssel nem boldogulok. Fűtőszál-ak rendben, hőkioldók szintén, ntc ok. A panelen hibát nem találtam. A programválasztó gombot 6 óra állásba tekrve és a schonen gombot 3 x megnyomva tudom tesztelni a perifériákat, ha jól gondolom. 8 ig lehet a startal léptetni, majd alapállásra vált. a 6. és a 7. állasban megy a fűtés. Így arra jutottam, hogy a szíj hiba miatt esetleg hibakód van tárolva, amit resetelni kellene. Nem tudok rájönni hogyan... Olvastam néhány topikot, de sem a 6 óránál 3 start, 7 óránál 3 start, se a 11 óránál törlés, sem a 2 óránál törlés sem segített. Ha valakinek van egyéb ötlete, ne tartsa magába.
A Privileg PWC 1716-os gép topikjában említettem meg ezt a gépet is.Ez azt csinálja,hogy ha elindítom akár tesztben akár programban,akkor elindítja a dobot de csak pár másodpercre,majd leáll,vár pár másodpercet,újra elindítja pár másodpercre,ismét leáll pár másodpercig,és harmadszor is ugyanez és ekkor dobja ki a kódot.Másik hibakódot csak egy esetben dob,ha lehúzom az NTC csatlakozót a panelról.Ha a dob forgását figyelő érzékelőt húzom le(ez egy csatlakozóban van az ajtó csukott állapotát figyelő érzékelővel),akkor hiába nyomom a startgombot nem indul el.Ez viszont logikus is,mivel nem érzékeli az ajtó zárt állapotát.Valamint akkor is ez az utóbbi történik,ha a négy vékony fekete vezetékes csatlakozót húzom le.Ezek a szivattyúnál lévő érzékelőhöz és a lábazat tetején lévő érzékelőhöz vezetnek.Ennél a két esetnél nem jelez semmilyen kódot.Ez a három csatlakozó kivételével bármelyik másik lehúzása nincs hatással a fentebb leírt hibajelenségre és az F10-et is változatlanul kidobja.Maga a kód a táblázat szerint a következő:a vezérlőpanel nem kommunikál az MCU-val.Ezt az MCU-t nem részletezi hogy micsoda,de én úgy gondolom,hogy a kezdőbetűk alapján Motor Control Unit vagyis motor vezérlő egység lehet.De javítsatok ki kérlek ha tévedek.A motor egyébként egy sima aszinkron motor egy üzemi kondenzátorral.Külön motorvezérlő panel(ami arra utalna hogy inverteres a gép)nincs a gépben.Ha magát a motorcsatlakozót húzom le a panelről,akkor persze nem forog a dob,csak a relé kattan és akkor is a fent leírt hibát produkálja.A különbség csak annyi a tesztben és a programban produkált hiba között,hogy programban a szivattyút is elindítja mielőtt a dob forogni kezd.Köszönöm ha elolvassátok.Segítségetek előre is köszönöm.Üdv:Ladakölyök
