Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Ez a fejegység a garázs szomszédom régebbi mercijében van. Egyik napról a másikra elnémultak a gombok, egyedül a hangerő encoder működik. Gyújtásra ki - be kapcsol, de a hangerőn kívül semmire nem reagál.
Állítólag nem ritka hiba ezeknél.
Egy fórumon valaki megjavította, de nem tudok oroszul a google meg valami ismeretlen szót ír:
Lezárom a témát, lecseréltem a protsyk-ot és minden működött.
Ezt nem tudom mi lehet...
Link:
https://monitor.net.ru/forum/threads/384471/
Lehet egy beragadt gomb, de kitűnő állapotban van, és nem hinném hogy gomb hiba - de átméregetem ha sikerül hozzáférni.
Beindítani sem sikerült még az autó nélkül, de ez úgy látom másoknak is nehezen sikerült.
Joco
Az autóba visszatéve rendben működik. Tehát kiszedve csak tápot ráadva NEM működik fél percig. Csak szerviz módba indul, de úgy is zombi - csak a logó van a kijelzőn.
Hogy mi volt a készülék hibája azt nem tudom. Talán valami kontakt hiba, vagy eleve rendbe jött volna a tápelvételes újraindítástól. Így legalább értem miért nem találtam semmi hibát a méregetés közben.
Egy Becker Grand Prix BE1311 autórádióhoz keresek LCD kijelzőt , hátha valakinél elfekszik egy ilyen készülék ami nem javítható de a kijelző még ép .
Köszönettel , Gábor
Mercedes Becker BE2210 autórádió alkatrészbeazonosításban.
Csatoltam képet az alkatrészről.
Szerintem a felirat miatt egy 4,19 ohm os ellenállás lehet ami védelmi szerepet tölthet be.
Jól gondolom?
A tastaturán található a kijelző alatt.
Chassit sajnos nem találtam hozzá.
Esetleg ha vlenne valakinek azt is megköszönném.
Üdv.:
Gyula
