Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Meg állt a tudomány.
Táp 8,5V és 5V rendben.
kijelzőn semmi gombokra nem reagál.
Bekapcsolom kis áramfelvétel van.
zárlatot nem mérek.
mi lehet vele?
Előélet:
Az autó több éve állt. Autóban a rádió bekapcsolt kódot kért de az első számjegyen kívül nem érzékelte a többit. Mondom roszak a gombok.
kiszedtem a rádiót szét sem szedtem de már az asztalon nem indult be.
Szétszedtem agombokból 3 valóban nem működik.
mást nem találtam
még.
Mercedes Becker BE2210 autórádió alkatrészbeazonosításban.
Csatoltam képet az alkatrészről.
Szerintem a felirat miatt egy 4,19 ohm os ellenállás lehet ami védelmi szerepet tölthet be.
Jól gondolom?
A tastaturán található a kijelző alatt.
Chassit sajnos nem találtam hozzá.
Esetleg ha vlenne valakinek azt is megköszönném.
Üdv.:
Gyula
Került hozzám egy Mercedes Becker Truckline CD65 autórádió,van benne egy alkatrész ami szénné égett és sehol sem találok hozzá rajzot.
Nehezít hogy a Becker ritkán hagyja meg a félvezetőkön a gyári jelölést,a látszó töredékekkel sem megyek sokra...
És mivel 24v-os,és gyanitom hogy a táp körben van,még csak hasonló Beckerről sem tudom lesni.
Én esetleg SOP8 tokozású regulator IC-re gondolnék,annyi látszik hogy a 5-8 lábak párhuzamosak.
Van esetleg tippetek,milyen alkatrész lehet,vagy esetleg rajza valakinek hozzá?
Köszönettel
A karcsú sertés
