Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Keresem WEGA JPS 351V-130 erősítő kapcs. rajzát, továbbá szükségem lenne egy db tárgyi erősítőben lévő SONY gyártmányú 28B 171006 jelzésű meghajtó IC-re.
Üdv.:tothotto
Kedvenc kis masinám cserben hagyott... nem akar rendesen dolgozni. Ugyebár ennek bejövő jel nélkül ki kellene kapcsolnia, de nem teszi. Ami még zavaróbb, hogy "LFE" bemenetről szinte csak sugdolózik.
Lehet tud valaki így "távgyógyítással" segíteni. :help:
Üdv, Z.
Lentebb a megoldás. Ami a kikapcsolást illeti, nos összerakás után az is rendben. Vélhetően nem ártott, hogy helyére kerültek az árnyékolások, stb.
Köszönöm mindenkinek a segítséget! :beer:
Üdv. Segítséget kérek! Egy sharp sx 8800 H erősítő hibás!
a hibája hogy van A+B oldal meg még 2 külön álló oldal
na most az A+B oldal úgy szól ha csak az A ra van kötve vagy csak a B re a kettő együtt nem szól
a külön álló oldal meg egyáltalán nem szól
ami okozhatja IC STK 4050 H 2DB van benne
meg egy tranzisztor de nem tudom kimérni őket mert nem tudom az értéket hogy mennyinek kell lenni-e
Képek: http://kepfeltoltes.hu/120225/IMAG0073_www.kepfeltoltes.hu_.jpg
http://kepfeltoltes.hu/120225/IMAG0074_www.kepfeltoltes.hu_.jpg
http://kepfeltoltes.hu/120225/IMAG0076_www.kepfeltoltes.hu_.jpg
Válaszokat előre is köszönöm!
