Tisztelt Fórumtársak! Nem vagyok jártas rádióhangolás területén. Így a segítségeteket kérem. Egy fent kelzett tunert életrekeltettem, elkókat cseréltem. Csupán annyi hibája van, hogy el van mászva a hangolás. Pl 89.5MHz adót 89,48-on találja meg. És a foton látható STEREO és TUNED LED-ek, tovabbá a Vételerősség sor, csak 10 perc elteltével jeleznek. Hol kezdjem a hibakaresést ?
Mi a véleményetek eme erölködőről???
Érdemes nekifognom?
3 éve áll itt ez is :S
Halvány fogalmam nincs egyenlőre mivan vele, ha aztmondjátok gagyi akkor hagyom a fenébe.
Pityesz
Hello, I am in a repair KENWOOD KRF-X9995D.
Let me know if anyone is aware of how to reset the processor.
That is about a year ago I had the same problem with another amp of the same model!
So this is the second unit can not repair!
The main flaw is that the accumulation of around 1F 5.5V had spilled acid. was also in the same thing happened! ie it shows mute, but going into test mode, (having pressed the key "INPUT SELECTOR DOWN" and "POWER", the analog input works (but only in TEST).
Any help?
Thank you
Hi to all,
I am looking many days for schematics for the LAX MA7200 audio amplifier.
I think it is made in far east and is copy of other model, probably a QSE brand.
Similar to this-or made from the same factory-is the ODY-PRO 7200, which has a board with a printed label "XILICA" which is a Canadian company.
Any of the schematics is great help for me, as I have to service more than 20 units.
In case you met any of them please inform.
Thanks for your time for reading
