BROTHER DCP-L5500DN,L5502,L5600,L5602,L5650,L5652DN,L6600DW MFC-L8530,8535,8540DN,L5700,5702,5750,5755,5800,5802,5850,5900,5902,6700,6702,6750,6800,6900,6902DW SM
PRINTER - SERVICE MANUAL
29.3 MB
PRINTER
Looking for similar brother manual?
BROTHER DCP-L5500DN,L5502,L5600,L5602,L5650,L5652DN,L6600DW MFC-L8530,8535,8540DN,L5700,5702,5750,5755,5800,5802,5850,5900,5902,6700,6702,6750,6800,6900,6902DW SM service manual (1st page)
Preview of BROTHER DCP-L5500DN,L5502,L5600,L5602,L5650,L5652DN,L6600DW MFC-L8530,8535,8540DN,L5700,5702,5750,5755,5800,5802,5850,5900,5902,6700,6702,6750,6800,6900,6902DW SM [1st page]
BROTHER DCP-L5500DN,L5502,L5600,L5602,L5650,L5652DN,L6600DW MFC-L8530,8535,8540DN,L5700,5702,5750,5755,5800,5802,5850,5900,5902,6700,6702,6750,6800,6900,6902DW SM service manual (2nd page)
Preview of BROTHER DCP-L5500DN,L5502,L5600,L5602,L5650,L5652DN,L6600DW MFC-L8530,8535,8540DN,L5700,5702,5750,5755,5800,5802,5850,5900,5902,6700,6702,6750,6800,6900,6902DW SM [2nd page]
    BROTHER L-5502 L-6600DW MFCL-8530 L-5700 DCPL5500DN L5502 L5600 L5602 L5650 L5652DN L6600DW MFCL8530 8535 8540DN L5700 5702 5750 5755 5800 5802 5850 5900 5902 6700 6702 6750 6800 6900 6902DW DCPL 5500 DN 5502 5600 5602 5650 5652 6600 DW MFCL 8530 8540 5700 6902 DCP L5500DN MFC L8530 MFC-L8530
Relevant PRINTER forum topics:
Brother HL2170W lezernyomtato nem akar bemelegedni MEGOLDVA
Sziasztok. Mar egy jo ideje kaptam egy Brother HL2170w nyomtatot, egy 50w-os (!) 110v-os adaptert es a spaci kabelt, azzal a keressel, hogy nem muxik, javitsam meg. Latvan hogy a cucc Amerikabol szarmazik, mondom a tulajnak, hogy en megjavitom, de a javitas koltsegeihez adja hozza egy kb 1 kw-os 110v-os trafo arat is, ami bizony eleg sokba fog fajni neki. Erre azt mondja: akkor dobjam el, neki nem eri meg ennyi penzt fektetni bele. Nem dobtam el, mostanig oriztem, mert nem volt idom ra. Most kibontottam, es a tapban csak egy 125v-os tulfeszvedo (z1) adta meg magat es termeszetesen az F2, a 4A-s bizti. Z2-bol (10A) nem jott ki az elteto fust, Z50 gyarilag ki van sporolva. Ezeket azert irom igy le, mert a SM fennt van a Tanyan, en is innen okultam (volna). Sokat gondolkoztam, ha megjavitom a tapot, mi legyen a tovabbi sorsa, hiszen nekem sem all modomban egy ekkora bazi nagy trafot tenni melle. Inkabb levalasztom a nagy fogyasztot, a kemencet, kicserelem a lampat egy 220v-osra es direkt adok neki halozati feszt, a tapot meg a csomagban kapott 50w-os adapterrel taplalom 110v-al. Mindez meg is tortent, az F1 es F2 kozos pontjarol levalasztottam a kemencet es beadtam neki a 220v-ot, a tapot magat pedig 110v-al taplaltam. Elindul, megvan a 24v es az 5v, de mind a 4 led villog, megnyom GO gomb kigyul a toner led >> a SM szerint fuser error. Kicsereltem a triakot (az eredetinel G - A1 300ohm, a masiknal 100ohm /mas tipusuak/), de semmi valtozas. A PC2 optocsatolo triak labain 90vac-t merek, a TRA1 triak A1-A2 labain szepen megvan a 220v. Ezen a ponton, mas otlet hijan visszaallitottam az eredeti, 110v-os elrendezest, de semmi valtozas a mukodesben/hibakodban. Ha valakinek van valami otlete, szivesen veszem, megkoszonnem. Ja, es szkopom nincs, csak egy alap multimeter.
Brother HL1230 nem nyomtat. MEGOLDVA
Nevezett gép feláll, tesztet a pc-ről, és magáról is tökéletesen kinyomja, de ha egyéb oldalt akarok nyomtatni akkor csak üres lapok jönnek. Hibát nem jelez, a nyomtató ablakban jelzi a dokumentumot, a kapcsolat megvan, a gépen a "Data" led világít amig le nem megy a nyomtatás.
Köszönök minden segítséget.
Brother DCP-357C nyotatófej kiszerelése és tisztítása
Kaptam egy Brother DCP-357C kombinált nyomtatót. A szkenner működik, a fej viszont beszáradt állapotban volt (a nyomtó részt már évek óta nem használták). A nyomtatófej alá ioncserélt vizes kéztörtlő papírt téve, sokadszori próbálkozásra a szines fejek beindultak, de a fekete nem. Szeretném kiszerelni a fejet egy alaposabb (közvetlen oldószeres) tisztításhoz, de kéne hozzá a szervízkönyv. Ha valaki tud DCP-350C, DCP-353C vagy DCP-357C szervízkönyv elérhetőséget, nagyon megköszönném, ha segítene. Van egy kerregő hang (ez a próbálkozások közt jött elő) amikor a nyomtatófej a bal szélső helyzetbe mozdul. Oda is szeretnék "bejutni", megnézni, hogy mi okozhatja. Szervízkönyv nélkül nem akarok kísérletezni. Üdv. Gábor
Brother DCP-115C
Segítséget szeretnék kérni egy Brother DCP-115C nyomtató javításával kapcsolatban. A hibajelenség az LCD kijelzőn: Nem lehet nyomt. Szervizmenübe lépve Error code 51. Látszatra elkezd tesztet végezni a nyomtatófej, a két véghelyzet között mozog, és tisztítást végez, majd megáll, és a fenti hibaüzenetet adja a készülék. A készüléket tisztítás lehetetlen hibával hozták, ezt megoldottam, majd miután a gépet még teszteltem, hálózatból ki-be, utána jött a most tapasztalt hiba, itt megakadtam. Úgy tűnik nem szorul semmi, a fej kézzel könnyen mozog. Eddig még nem találkoztam ezzel a típussal, lenne valakinek ötlete, mi lehet a hiba oka? Vagy egy szervizkönyvet tudnátok küldeni? Köszönöm előre is a segítséget!
