CAMBRIDGE-AUDIO CD3 SCH
124.5 KB
Looking for similar cambridge manual?
CAMBRIDGE-AUDIO CD3 SCH service manual (1st page)
Preview of CAMBRIDGE-AUDIO CD3 SCH [1st page]
CAMBRIDGE-AUDIO CD3 SCH service manual (2nd page)
Preview of CAMBRIDGE-AUDIO CD3 SCH [2nd page]
    CD-3 CD3 CD CAMBRIDGE AUDIO
Cambridge Audio Azur 851A doesn't turn on
Hi all !
I plug the plug into the socket. The blue standby LED lights up. I press the standby button. But the amplifier does not turn on, the LCD display does not light up. When you press the standby button again from the 15th to the 20th time, sometimes it is possible to turn on the amplifier. Previously, a similar thing happened after a long period of inactivity of the amplifier unplugged from the outlet. But after turning it on to the outlet and warming up in standby mode, everything seemed to return to normal, and the amplifier was turned on with the standby button the first time.
And now, after standing for 3-4 weeks (unplugged from the outlet), only from the 15th or 20th time.
Thanks.
Pye type 38H - Cambridge - Radio - Antique - Vintage
Please Upload Schematic, Service manual : Pye type, model 38H Cambridge Valves / Tubes 6: EF39 ECH35 EF39 EBC33 EL33 AZ31 Year: 1948 ? Country: Great Britain (UK) Thank you very much, Ruy
Cambridge AZUR 840E Service Manual wanted
Hi to all funs of Electronics. I am interested for Cambridge AZUR 840E preamp service manual. I would appreciate if someone can post a link for download or add this document at our database. Thanks in advance for your attention and help. Best regards, John
Cambridge Audio CAP5 védelmi rendszer aktiválódik
Elég ritka, de hátha találkozott már valaki ilyen jellegű hibával, problémával.
Volna egy Cambridge Audio CXA80 tipsú erősítő, ami védelmi módba megy át, függetlenül attól hogy hangfal van-e rákötve vagy sincs.
Hosszas (órák) kikapcsolás után 25-30 percig tökéletesen megy akár nagyobb hangerőn is, de ez időnél többet nem megy, melegedés nincs ez idő alatt.
Ezek után felvátva hol a 3, hol a 4 villogást produkálja, de egyre inkább a 4.
A 3-as kód túlterhelés, a 4-es kód a rövidzár.
Ediig a táp és a hangszóró relék lettek cserélve, de minden ugyan az maradt.
Mivel sajnos sevice manual nincs, addig nem akarom "szétbombázni", hátha valaki nyúlt már mélyebben ebbe a védelmi rendszerbe.
"3-as Leírás - A CAP5 V / I (feszültség / áram) védelmet kínál azáltal, hogy folyamatosan figyeli a kimeneti tranzisztorokat, hogy azok a SafeOperating területén (SOA) belül működjenek. A SOA egy sor korlátozás, amelyet a kimeneti tranzisztor gyártó ad a megbízhatóság biztosítása érdekében. A V / I védelem beépült az erősítő áramkörébe, hogy gyors választ adjon az ideiglenes túlterhelési körülményekre. A V / I védelem bekapcsolásakor az egység továbbra is működni fog, de torzulás hallható, mivel az egység védi a kimeneti tranzisztorokat"
"4-es Jelzés - Az egység kikapcsolt a bekapcsolás közben. A Direct, Speaker A / Band Mute jelzőfény együtt villog a következő sorrendben: négy gyors villanás hosszú szünettel a villogások között. További információkért olvassa el az alábbiakat. Leírás - A készenléti állapotból történő bekapcsoláskor a CAP5 ellenőrzi a hangszóró csatlakozóit, hogy megbizonyosodjon arról, hogy véletlenül bevezettek-e rövidzárlatot a csatlakozók között. Ha a hangszóró-terminálok között mért ellenállás túl alacsony, akkor az egység készenléti üzemmódban marad, amíg a hibát nem szüntetik meg, és az újraindítást meg nem kíséreljük."
Itt a cap5 védelmi rendszer https://www.manualslib.com/manual/972945/Cambridge-Audio-Cxa60.html?page=12
