Ez az a nyomtató ami a HP1320 teljes koppintása, csak kijelzőt kapott és más a programja. Kicsit megkergült ezért cserélném a progiját. Ja és ha valaki tudná a default beállítást az is segítség lehetne.
Köszi laci
Lenne egy kérésem hozzátok. Van egy CANON FAX-B180C nyomtatom ami a következő hibakódot
írta ki (##343). Ha valaki tudná mit jelent és hogy tudnám törölni hálás lennék neki. Előre is köszönöm. Üdv!
Saw lots of videos on these with error code B200. Cleaning the head seems to solve it many times.
So after I put the cleaned out printhead back in, I did the trick again
where u power it off when the carraige is half way to the left, remove power
andapply power.
This time, it said "processing" on the screen, and the carriage did alot of
extra maneuvers, and looked like it was attempting a cleaning cycle.
At the end, the screen said "cover open", and the carriage slid toward the
left,stopped, and (3) cartridge LED's were flashing slowly, which I was told
meansthose cartriges are low ink. If I closed the cover, the B200 error would
eventually come back.
I asked the customer if he had spare cartridges, and he did, so he bought
them over, we put them in , tried again, and same B200 error.
I told him its likely a print head, and he may try ordering one thru ebay or
something to give that a try. Apparently there are microelectronics inside these
heads? Beats me how they control or regulate ink flow. On the back of the head there are about
50 contact pads, which I guess must be sensors of some kind? He did say he took the head out
at one point, and perhaps ESD may have damaged some sensitive circuitry in
there, and now the head is out of spec.
I thought I saw some russian videos jumpering some of the pads on the head to bypass the code....anyone have any success?
Kedvenc kis nyomtatóm meglepett valamelyik nap. Bekapcsoláskor pár másodpercet követően "elsötétült". Ellenőrizve a vezetékeket minden rendben volt, így jött a szétszerelés. Szerencsére "javítás barát" a tápegysége, egy külön részben helyezték el amit egyszerűen ki lehet húzni belőle. Első ránézésre semmi nem utalt a hibára. Méricskélés és kondik ellenőrzése során kiderült, primer puffer elko lába elrohadt. Csere és próba.. de csak reménykedtem, hogy ennyivel megúsztam. A tápegység indul, viszont kimenetein 6 és 10 volt mérhető a névleges 24-32 helyett. TL, opto, táp ic cserélve, diódák szintén. Jelenség ugyanaz. Gyanítom a bekapcsolásnál kap(na) vissza az elektronikától egy vezérlést ami ebből az alacsonyabb szintből emelné a tápot, de ez korántsem biztos. Szóval ha valaki esetleg ismerné, vagy találkozott már ilyen szerkentyűvel, megoszthatná velem "ötleteit", mert én elakadtam.
Köszönettel: Kiss Z.
