Saw lots of videos on these with error code B200. Cleaning the head seems to solve it many times.
So after I put the cleaned out printhead back in, I did the trick again
where u power it off when the carraige is half way to the left, remove power
andapply power.
This time, it said "processing" on the screen, and the carriage did alot of
extra maneuvers, and looked like it was attempting a cleaning cycle.
At the end, the screen said "cover open", and the carriage slid toward the
left,stopped, and (3) cartridge LED's were flashing slowly, which I was told
meansthose cartriges are low ink. If I closed the cover, the B200 error would
eventually come back.
I asked the customer if he had spare cartridges, and he did, so he bought
them over, we put them in , tried again, and same B200 error.
I told him its likely a print head, and he may try ordering one thru ebay or
something to give that a try. Apparently there are microelectronics inside these
heads? Beats me how they control or regulate ink flow. On the back of the head there are about
50 contact pads, which I guess must be sensors of some kind? He did say he took the head out
at one point, and perhaps ESD may have damaged some sensitive circuitry in
there, and now the head is out of spec.
I thought I saw some russian videos jumpering some of the pads on the head to bypass the code....anyone have any success?
Sziasztok ! A fenti nyomtató hibaüzenete !Could not correctly set the Printing Position Adjustment for each of the toner cartridges. Cancel the jobs, and then try to perform calibration again. Ha valaki tudja a megoldást kérem segítségét ! Üdv!
Olyan kérdéssel fordulnék hozzátok kedves takarékos kolégák, hogy ebbe a nyomtatóba rakható-e a chipeletlen patron??? átrakható-e a régi chip??? miket kell elkövetni ilyenkor, hogy működjön???
Köszi minden segítséget
stonhy
Ez nem igazán javítási ügy, lehet, hogy nem ide kellene föltennem...
A kedvesemnek van egy szgépe, azon pedig a Windows 10 van telepítve. És van egy Canon Prixma MP210-es nyomtatója, amivel tud nyomtatni.
Viszont most kellett volna scennelni, de nem tud, mert a telepítő programok között nincs ehhez a nyomtatóhoz illesztő-telepítő program.
Tudna valaki segíteni, úgy, hogy meg is értsük, mert mindketten a laikusok táborához tartozunk ebben a témában.
Köszönettel:
