Saw lots of videos on these with error code B200. Cleaning the head seems to solve it many times.
So after I put the cleaned out printhead back in, I did the trick again
where u power it off when the carraige is half way to the left, remove power
andapply power.
This time, it said "processing" on the screen, and the carriage did alot of
extra maneuvers, and looked like it was attempting a cleaning cycle.
At the end, the screen said "cover open", and the carriage slid toward the
left,stopped, and (3) cartridge LED's were flashing slowly, which I was told
meansthose cartriges are low ink. If I closed the cover, the B200 error would
eventually come back.
I asked the customer if he had spare cartridges, and he did, so he bought
them over, we put them in , tried again, and same B200 error.
I told him its likely a print head, and he may try ordering one thru ebay or
something to give that a try. Apparently there are microelectronics inside these
heads? Beats me how they control or regulate ink flow. On the back of the head there are about
50 contact pads, which I guess must be sensors of some kind? He did say he took the head out
at one point, and perhaps ESD may have damaged some sensitive circuitry in
there, and now the head is out of spec.
I thought I saw some russian videos jumpering some of the pads on the head to bypass the code....anyone have any success?
Van két darab fejhibás Canon IP-1500 nyomtatóm eladó ,ha valakit érdekel!!!
Üdvözlet a Tanyalakóknak.
A címbeli készüléket, nyomtatás-képtelenséggel hozták hozzám.
Nem szívesen, de mivel jó szomszéd a tulaj, megnéztem.
Szerencsére (természetesen) a Tanya adatbázisában találtam is anyagot róla, és eljutottam a következőkig:
-Bekapcsolás után, fej, jön megy, majd az alaphelyzetbe állás után, a hiba-led, ötöt villog. Három hibalehetőséget említ az SM, mindhárom a nyomtatófejjel kapcsolatos.
1-nyomtatófej nem, vagy hibásan behelyezve.
2-nyomtatófej hőmérséklet szenzor hiba.
3-hibás nyomtatofej EEPROM tartalom.
A tintapatront takaró fedelet felnyitva, a szán beáll "csere"állapotba.
-Szervízmenűben, a fej alaphelyzetben marad, és a fedél felnyitására sem reagál. A bekapcsolást jelző zöld, és a hibajelző sárga LED felváltva nyolcat villog, ami az álmoskönyv szerint, a nyomtatófej hőmérsékletének hibájára utal.
Gugli barátunk, találataiban, utalások vannak szervíz, vagy "general tools" programokra, de letölthetőt, nem találtam. (fájlcserélő programom nem is lesz!)
Hozzáértő kollégák segítségét keresem, szeretném rendbe tenni, mert
gazdája a tönkremenetelét megelőzően, vett hozzá egy garnitúra festékpatront.
Jelenleg az EREDETI patronok vannak benne, amikkel megállt.
Megtisztelő válaszaitokat előre is köszönöm:
exGelkás
Gazdija, úgy döntött, hogy a nyomtatófej helyett, inkább az olcsóbb, komplett új készüléket veszi meg. Gyarapodik az e-szemétdomb.
Szép jó napot kívánok mindenkinek.
Van egy Canon Mp540 multifunkcionális nyomtatóm,amiben a CLI-521M Magenta patront nem akarja elfogadni.
Utánagyártott patronokat tettem bele a piros kivételével mindegyiket elfogadja.A régit visszateszem üresnek jelzi.Nem tudja valaki,hogy hogyan lehet reset-elni a tintaszintet.Miért nem látja az új patront aszt jelzi hogy nem lehet felismerni a tintapatront.
