Lenne egy kérésem hozzátok. Van egy CANON FAX-B180C nyomtatom ami a következő hibakódot
írta ki (##343). Ha valaki tudná mit jelent és hogy tudnám törölni hálás lennék neki. Előre is köszönöm. Üdv!
Hello !
Keresek olyan elektronika hibás Canon S 820D nyomtatót amelynek a mechanikája tökéletesen működik ,mivel az enyémnek az egyik kis fogaskerekéből egy fog kitörött igy ott állandóan megakad .
Ha valaki tud segíteni írjon !!
Üdv :János
Saw lots of videos on these with error code B200. Cleaning the head seems to solve it many times.
So after I put the cleaned out printhead back in, I did the trick again
where u power it off when the carraige is half way to the left, remove power
andapply power.
This time, it said "processing" on the screen, and the carriage did alot of
extra maneuvers, and looked like it was attempting a cleaning cycle.
At the end, the screen said "cover open", and the carriage slid toward the
left,stopped, and (3) cartridge LED's were flashing slowly, which I was told
meansthose cartriges are low ink. If I closed the cover, the B200 error would
eventually come back.
I asked the customer if he had spare cartridges, and he did, so he bought
them over, we put them in , tried again, and same B200 error.
I told him its likely a print head, and he may try ordering one thru ebay or
something to give that a try. Apparently there are microelectronics inside these
heads? Beats me how they control or regulate ink flow. On the back of the head there are about
50 contact pads, which I guess must be sensors of some kind? He did say he took the head out
at one point, and perhaps ESD may have damaged some sensitive circuitry in
there, and now the head is out of spec.
I thought I saw some russian videos jumpering some of the pads on the head to bypass the code....anyone have any success?
Sziasztok Mesterek!
Adott a címbeli probléma. A nyomtatót szétszedtem, kitakarítottam, de a resetelés nem sikerül. Próbáltam már HW és SW úton is.
HW:
1. Kapcsolja ki a nyomtatót, és húzza ki a tápkábelt.
2. Tartsa lenyomva a POWER gombot, csatlakoztassa a tápkábelt.
3. A (L.E.D.) kell zöld.
4. Nyomja meg és engedje fel a Folytatás gombot, a kijelző (LED) kell narancssárga.
5. Nyomja meg és engedje fel a Folytatás gombot, a kijelző (LED) zöldnek kell lennie.
6. Engedjék szabadon az összes gomb.
(Spanyolból gugli fordította)
Waste Error Reset
1: Power off printer
2: Hold RESUME button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5. Release POWER button
6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
7: Press POWER to set data
"Magyarul":
Hulladék hiba visszaállítása
1: Kapcsolja ki nyomtatót
2: Tartsa Folytatás gombot nyomja meg és tartsa lenyomva a POWER, a hangjelzés megszólal egyszer.
3: Tartsd POWER és engedje RESUME
4: Nyomja meg kétszer RESUME
5. Release POWER gombot
6: Amikor a jelzőfény folyamatosan, nyomja meg a FOLYTATÁS három (3) alkalommal. A mutató narancssárga.
7: Nyomja meg a POWER adat-
Egyik sem működik. Visszakapcsoláskor megint jön a hibaüzenet.
SW:
IPtools 1.1.3 ha a nyomi ki van kapcsolva, elindul. Nyomi be, bal ablakban a típust felhozza, de tovább semmi. Belefagy. Ha a nyomi be van kapcsolva és úgy indítom, csak fehér ablak és fagyi.
General Tool elindít, nyomi bekapcs. A DEVICE ID-t kiolvassa, de minden másba belefagy.
Kérlek segítsetek, mert 2 napom ráment és csakazértis szeretném megmenteni Földünket egy újabb elektronikai szeméttől!
Köszönettel:
Gyula
