Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
Hozzám került eme remek csoda,amiben cseréltem a színvégfokot.
Most már jó lett,de egy kissé pirosas még a kép ezért egy szervizmenü
belépési kódnak nagyon örülnék.Továbbá érdekelne még,hogy ezeknek
valóban ennyire vacak-e a képcsöve.A tulaj azt mondja,csak esténként
használták pár órát,de a képcső állapota nem ezt mutatja.Könnyen lehet
a végfok is emiatt szállt el.Milyen képcsövet ajánlotok helyette??
A tv pontos típusa Thomson 29DC830
Köszi!!!
Kedves kollégák!
Ehhez a TV-hez keresek SPI és NAND tartalmat esetleg USB-st. Úgy néz ki,hogy tartalom hibás,hasonló lappal működik,csak a táv nem megy.
LCD: Ves315wnds-2d-n13
üdv.
Én most fórumozok itt először. Aktívan televíziójavítással foglalkozom.
Találtam ismét egy jó hibát! Vagyis nem találtam még meg csak gyanúm van.
A hibajelenség: szobahőmérsékleten (18-22C-fok)bekapcsolást követően megjön a kép és hang. Ez tart kb. 4mp-ig és kikapcsol a tv.Ilyenkor kicsit mosott a kép is. Ezt a ki-bekapcsolgatást megcsinálja kb. 5-10 alkalommal és azután működik rendben. Talán típushiba?
Valami kondira gyanakodtam?! Hűtőspray-vel elkezdtem keresgélni és a videómeghajtó panelon a CXA2165Q ic-nél reagált a hiba a legérzékenyebben. Nem tudom biztosra állítani hogy az ic-e valójában a hiba oka mivel nem tudtam beszerezni és kicserélni. Lehet talán nyák is vagy talán fáradtabb alkatrész körülötte? A lényeg ha bemelegítem egy kicsit az ic-t akkor gyönyörűen működik! Amúgy elég érzékeny az ic és környéke a spray-re. Talán átvezet és beleszól valahol a spray is a működésbe?!
Nem-e volt valakinek valami hasonló jelensége? Nem lehet-e valami opcionálisan határra beálítva?
Köszi előre is!
Amúgy Kellemes Ünnepeket kívánok minden tanyasinak!
