Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
A kimeneten elszált egy tranzisztor amit nem tudok beszerezni, a helyettesítőjét is csak nagyon nehézkesen.
Ezért egy bontott panelt keresnék, amiből ki tudnám menteni!
Előre is köszönöm.
Elsősorban: SL-PG 290;390;490 lenne jó, de más is jó lehet.
Amibe kell az egy 490-es.
Sziasztok'
Szintén javítani akarta már valaki az egyik oldalon hiányoztak a végtranzisztorok, a másik oldal nem lett bántva.
Sajnos oszciloszkópom nincs mert karácsonykor véletlen rátapostam a NYÁK-jára (megakartam javítani a tápját :) )
Végfokok IRF640 2db, végfok tápja +/-48V, de az előfoké +58V/-48V (hihetetlen de séma szerint is ennyi).
Mindkét oldalon ugyanazok voltak a feszültségek.
Tranzisztor nem ég ki a végfokban.
Védelmi relé nem engedi a hangszórót rákapcsolni.
Most az egyik oldalt végtranzisztorjait kiégettem nemtudom hogyan miközben rámértem a Q101-es tranzisztor bázisára. Most akkor a másik oldalt javítanám..
Méregettem pár feszültséget és beírtam a rajzra pirossal.
Nem tudom miért van -18V a kimeneteken ( a másik oldalon is maradt a -18V tranzisztorok nélkül is)
Minden félvezetőt durván átmértem jónak tünnek...
MX 5021-gyel van valakinek tapasztalata? Ugy nez ki, hogy 10+ ev mukodes utan megadta magat:
- a kontroller vilagit, tudok "hangerot" allitani rajta, de
- tekeresnel csak pattogo hang jon a hangfalakbol,
- hang egyaltalan nem jon belole, ha a jack kabelen rakuldok barmilyen hangot,
- a kontroller reszt szetszedve nincs puposkondi, vagy mas, gyanus IC
- a melynyomot (illetve az erosito reszet) nem szedtem szet me'g
Merre erdemes indulni? Par helyen azt irjak, hogy az ST L7809CV es a JRC 7909A IC-ket erdemes kicserelni. Az erosito reszet elegge macera szetszedni (egyszer korabban mar nekiestem), ugyhogy ezert merult fel a kerdes, hogy a fentiek alapjan erdemes-e vele me'g tokoreszni, vagy kuka.
Koszonom,
-w-
