Hi!
Lenne egy ilyen rádió
Rettenetesen halkan szól. max. hangerőn is csak ha közel hajolok a
hangszóróhoz akkor lehet hallani. TDA8587J van benne. A hangproci TDA7460N. Ha a 20-as CREF lábon lévő 100u/16V-os kondit kivéve és megforgatva, érintgetve megjött a hang, és meg is maradt a következő kikapcsolásig. Az adatlap szerint ez proci a belső tápjának a ref kondija. Volt valakinek ilyen hibája?
köszi
Üdvözletem !
Philips Szervízes Mestert keresek , ha van közöttünk .
Segítséget szeretnék kérni , vagy egy ilyen eladó monitort keresek.
Öreg Tom
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Tisztelt Kollégák, Fórumtársak!
A készülék az enyém és legutóbbi használat során nem volt vele semmi probléma. Mivel nincs mindennap bekapcsolva ma kellett volna rögzítenem egy hosszabb műsort és azt vettem észre, hogy hiába csatlakoztatom a tápegységéhez (5V/1A) arról nem hajlandó működni. De ha bele teszek két akkut akkor azzal elindul, de egy óra múlva jelezte, hogy az akkuk gyengék ki kell cserélni.
Tápegység jó! Stabil 5V mérhető, terhelés mellett! A készüléket szétszedtem hátha a tápcsatlakozó nem okés, de nem volt vele baj. Viszont van benne egy modul ami teli van DC/DC konverterekkel. Ott lehet valami prücök... Ha javított már ilyen készüléket valaki, köszönettel várom jelentkezését!
Minden segítséget előre is köszönök!
Üdvözlettel: Zoltán.
Megoldódott! Egészen elementális hiba volt, a tápdugó korrodált volt belül ezért forgatásra hol érintkezett, hol nem... Meg kellett tisztogatni és utána jó lett.
