EPIPHONE EA-70 SCH
474.0 KB
Looking for similar epiphone manual?
EPIPHONE EA-70 SCH service manual (1st page)
Preview of EPIPHONE EA-70 SCH [1st page]
    EPIPHONE EA-70 EA70 EA 70
Pye type 38H - Cambridge - Radio - Antique - Vintage
Please Upload Schematic, Service manual : Pye type, model 38H Cambridge Valves / Tubes 6: EF39 ECH35 EF39 EBC33 EL33 AZ31 Year: 1948 ? Country: Great Britain (UK) Thank you very much, Ruy
Klipsch ProMedia 2.1 Amplified speakers
Original problem is no sub woofer output. Been through this one and recapped it and the common 2 burned 1K (R16/17)
resistors are replaced but the sub is still not responding. Volume control potentiometer is a common issue on these but
the L-R spkrs sound good.
Went by this webpage on the repair:
https://christopherbradshaw.net/The_Project_Bin/klipsch%20promedia%20subwoofer%20repair%20-%20page%201.html
On the schematic there is a sub-relay (sw101) powered by +V_HF line it
maybe is suppose to be +V_LF ? Without the relay coming on looks like the sub is disconnected.
The zeners (D03/04) that give +/- Vcc to the op amps seemed way off so I replaced them and the voltages seem much closer.
Theres also a sub-mute line on p104 to p101. Power supply shows the LF mute relay and interconnect diagram says it
gets fed from the LF amp. What is triggering the mute? I dont see a mute button anyplace.
Denon PMA-260 trafó hiba!!
Sziasztok. Adott egy DENON PMA-260 eroszíto..Kaptam...Sajnois nem kapcsol be, megmértem a tekercset sajnos nem kap áranot. Esetleg valakinek kapcsolási rajz? Koszonom szépen
DAEWOO AMI324R HIFI Nem jó a CD lejátszó
Jó estét mindenkinek! Nem minden lemezt játszik le. Csak komplett CD mechanikát találok hozzá , lézerrel tertóval együtt, de az több mint 10000Ft. Tudja valaki milyen lézer van benne mert a szerkezeten nincs rajta? A CD mechanika száma DOP110B Dínó
