This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Sziasztok!Olyan gondom van ezzel az mp3-as autocd-vel,hogy a lemezt nehezen olvassa be,de van mikor rögtön,van mikor többszöri ki-be adatással tud csak lemezt felismerni.Ha viszont beolvasta akkor megy rendesen.A története annyi,hogy karambolozott az autó amiben volt.Előre is köszönök minden infót!
Nosztalgiából vettem magamnak egy Videoton RM4624 Star De Lux rádiósmagnót.
Kiváló állapotnak örvend, de 1-2 dolog javításra,pótlásra szorul.
Mind az AM rész, mind a magnó rész hibátlan,nagy hangerővel, elfogadhatóan szól.
Az FM viszont halkan,illetve teljes hangerőn csak kb 1/3-ad hangerővel szól.A dinamika érezhetően meglenne benne.
Nem látok "belepiszkálást", de azért nincs kizárva,előfordulhat.
Tippeket kérnék a javításához, de inkább közelemben, Gyálhoz közeli szakembert keresnék aki vállalná hogy átnézi, beállítja,szükség szerint javítja a készüléket.
Valamint keresek hozzá kazetta ajtót is, mert ez eléggé "feszegetett", kikopott állapotban van.
Akinek lenne ilyen, kérem jelezze, szívesen megvásárolnám.
Köszönettel:Csaba
Az lenne a kérdésem a kollégákhoz, hogy tud-e valaki megoldást az ennek a típusnak a rádióját jellemző általános hibára, nevezetesen a rádió állandó elhangolódására (a rádiót FM hullámsávon hallgatva pár percenkét újra kell hangolni a rádiót, mert elmászik az adóról a készülék)? Kettő is van belőle a környezetemben, és mindkettő ugyanezt produkálja. Olvasgattam netes fórumokat ezzel kapcsolatban, de a leggyakoribb megoldás a problémára a rádiómodul cseréje más típuséra. Valaki megtalálta már ennek a konstrukciónak a hibáját? RF műszerparkkal itthon nem rendelkezem, így a tunerbe találomra nem nyúltam bele, de ha megvan a megoldás, célirányosan azért megpróbálnám javítani.
Ennyi idő alatt már kijavíthattad volna a címet. "Videoton Cleopatra rádió probléma" helyett "Videoton Cleopatra rádió folyamatosan elhangolódik". Most még kijavítottam, de legközelebb letiltom!
Kalex
