Hozzám került a cimben szereplö szörnyeteg!
Nem gyári állapotu, mert a toroid helyett hiperszil van benne amelynek emelt a tápfesze 42 volt.
Müsorforrás nélkül kb 5 perc mulva langyos a jobb oldali végfok hütöbordája.
Viszont müsorforrással szépen torzitásmentesen szol.
Esetleg a nyugalmi árama lehet rossz?
Emelt tápfesz nem okoz gondot?
Letekert hangerönél semmi rendellenes zaj,illetve müsorforrás nélkül teljes hangerön sincs zaj.
Valaki elkezdte modifikálni, de teljesen pozitiv irányba.
üdv:atis
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Sziasztok, hozzam kerult egy Technics SU-X880 tipusu erosito eleg megviselt allapotban. Valami folyadek omolhetett bele, raadasul az emlitett ic kornyekere, igy azt hiszem kinyirta az ic-t. Vegigmertem az egesz erosito reszt, talaltam nehany szakadt ellenallast (jellemzoen a tapagakban), csere utan a -12v stab tranzisztor es az AN7062 nehany masodperc alatt forro. Ha a feltett kerdesre a valasz nemleges, volna egy masik kerdesem: hogyan tudnam ellenorizni a vegfok ic (SVI4004) mukodokepesseget, hiszen ha kiveszem az AN7062-t, a v.amp bemenete nem fog beallni 1.2v-ra. Lehetseges, hogy a +12v-rol ellenallasosztoval beallitsam neki az 1.2v-ot?
Sziasztok. Elozmenyek: az amplituner hibasan kerult hozzam, nem adott semmi eletjelt. A vegerosito egyik csatornajanak vegtranzisztorai voltak zarlatosak, az egyik meghajto ossze-vissza vezetett, es az egyik vegtranzisztor emiter ellenallasa volt megszakadva. Sajnos az eredeti tranzisztorokat csak eleg borsos aron lehet beszerezni, igy a hibas vegtranzisztorok helyebe BD249c/250c paros kerult, meghajtoknak pedig a 2SA1013/2SC2383 paros. Ezek utan a javitott csatornan mert feszltsegek nem igazan egyeznek a szervizkonyben szereplokkel. A mert feszultsegeket rairtam a beszkennelt rajzra. VR102 - bol beallitottam TR122 bazisan a -0.5v-ot, de a vegtranzisztorok bazisan csak +-0.44v van, az emiterellenallason nem merheto feszultsegeses. Ennek ellenere a csatorna mukodik/szol egy nelkulozheto probahangszorot rakotve. Sajnos szkopom nincs, igy nem tudom megvizsgalni a jelatvitelt. Kerlek adjatok valami tanacsot hol lehet a gubanc?
