FAULT-SOLUTION CHASSIS E1
TV - INFO-TIPS
11.0 KB
INFO-TIPS
Looking for similar fault manual?
FAULT-SOLUTION CHASSIS E1 service manual (1st page)
Preview of FAULT-SOLUTION CHASSIS E1 [1st page]
FAULT-SOLUTION CHASSIS E1 service manual (2nd page)
Preview of FAULT-SOLUTION CHASSIS E1 [2nd page]
    CHASSIS E-1 E1 FAULT SOLUTION
Hisense LCD TLM3233D (very white screen, Fault and cure)
Hello, I have this LCD TV which has a very white screen, the picture is visible. I could not find any fault on the CCFL Lamp inverter and was suspecting the T-Con panel of failure. The T-con panel is integrated in the control board. What i did is using "freeze it" cold spray i sprayed one of the IC's and it cured the fault. Perhaps the IC needs to be replaced. The part number is AS15-G. This component is not available for purchase in south africa and i would need to import it from china. This part is a LCD voltage buffer. Regards Angelos
SAMSUNG UE46D6200TSXZF TV T-CON fault?
Hi, Please help me. This is a t-con board fault ? Thank You.
