Good morning, I have a Harman/Cardon AVR1510 receiver with the following defect. When I change the function it goes into mute, sometimes it plays back to normal or it takes time to release the audio, I would like some help to solve this problem. Thank you very much in advance.
Ismét hozzám került egy harman sub, amit sikeresen újraélesztettem, a sub tökéletesen működik.
Viszont még olyan "hibája" van, hogy nem hajlandó kikapcsolni mikor auto standy- módban van.Szinte az összes kondit cseréltem már benne, de órák múlva is bekapcsolva marad, holott elvileg max fél óra után ki kellene hogy kapcsoljon.
Esetleg valaki tapasztalt valami hasonlót?
A sub újra a régi, az u203 cseréje után kb 18 perc tétlenség után standby üzemmódba lép.
For your information to repair
Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown)
can be changed without any other servicing
Harman Kardon Receivers; Series AVR 2000,3000...
"Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time.
"Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V.
"Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there.
"volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V!
"everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function.
Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts.
So i hope i can help you...
cheers SG.
A fenti géphez keresek sm-t. A tanyán lévők közt nem találtam. A barátunk is csak fizetőset mutatott. A masina egyik napról a másikra megkukult, egy szikra zaj sem jön belőle. Köszönöm
