Egy új talány ami megoldásra vár:
A fent említett készülék 10 perc hibátlan működés után kikapcsol készenlétbe
ez után vissza kapcsolható működik ismét.
Hamar rájöttem melege lehet mivel külső ventilátoros hűtéssel elmarad a kikapcsolás.
Viszont a készülék tartalmaz 2db. ventilátort és itt jön a kérdés 1: minek van benne
ha egyik sem működik? 2: miért kapcsol le előbb a túlmelegedésre?
Jelzem a hibát nem befolyásolja a nagyobb hangerőn való használat ill. hangfalak
nélkül is ugyan az a helyzet.
Üdv. steewi
For your information to repair
Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown)
can be changed without any other servicing
Harman Kardon Receivers; Series AVR 2000,3000...
"Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time.
"Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V.
"Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there.
"volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V!
"everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function.
Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts.
So i hope i can help you...
cheers SG.
Good morning, I have a Harman/Cardon AVR1510 receiver with the following defect. When I change the function it goes into mute, sometimes it plays back to normal or it takes time to release the audio, I would like some help to solve this problem. Thank you very much in advance.
Sziasztok`
Van nalam egy Harman Kardon ONYX STUDIO 3 Bluetooth hangfal.
Teljesen halott, nem jelez toltest es nem kapcsol be.
Egy Li-Ion 18650-es akkut hasznal aramforrasnak, ennek a feszultsege helyes.
A fo panelen talaltam ket elrobbant SMD biztositekot (FB21 es FB22)
Sajnos az a szerviz-konyv amit a tanyan is megvan, az nem ez a verzioja erositohoz valo.
Nincsen-e valakinek ehhez a verziohoz rajza esetleg?
Ennek a jelolese 40-0ONYX3-MAF2G
Nem szeretnek talalomra beforrasztgatni biztositekokat, de azt sem tudom, mit csatolnak, teljesen a sotetben tapogatozok.
Elore is koszonom a velemenyeket.
Minden jot,
Janos
