Good morning, I have a Harman/Cardon AVR1510 receiver with the following defect. When I change the function it goes into mute, sometimes it plays back to normal or it takes time to release the audio, I would like some help to solve this problem. Thank you very much in advance.
For your information to repair
Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown)
can be changed without any other servicing
Harman Kardon Receivers; Series AVR 2000,3000...
"Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time.
"Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V.
"Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there.
"volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V!
"everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function.
Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts.
So i hope i can help you...
cheers SG.
Új vagyok itt és nem is szakmám,de kidobni nem akarom és értékben meg annyit nem ér,hogy utazzak vele valahová szerelőhöz.
Szóval van a fő panel és mellette az oldalához rögzítve egy kisebb panel van. Van rajta filter meg minden ami a hang útjába nem kellene ezért amikkel a főpanelhoz van kötve vezetékek abból nekem csak az rca jelre lenne szükségem ill. hogy sztereo módban működjön.
Két kérdés:Melyiken tudom direktbe bevinni a hangot tehát közvetlen az rca aljzatra forrasztva és hogy a híd kapcsolót ki kapcsoljam,tehát normál sztereóba tudjam használni.Se vágás semmi másra sincs szükségem belőle.
Az erő működik bár úgy látom javítva volt. Van egy susogós alapzaja is,de a kondi el volt folyva amit ki cseréltem,bár a rajzon nem találtam és én szerintem utólag lett bele rakva. Valószínűleg gerjedés miatt tették bele. A lényeg,hogy minden felesleges áramkört ki kötném belőle.
Ha tudnám,hogyan kell ide betölteni megtenném,de a kapcsolási rajz linkjét tudom csak beilleszteni
http://elektrotanya.com/the_harman_kardon_ca240.pdf/download.html
Harman kardon soundsticks III került hozzám. Végfok hibával. A végfok TDA8561Q.
Sajnos rajzom nincs hozzá.
A problémám hogy nem tudom szólalásra bírni.
A végfok IC-t kiforrasztvan a végfok IC 14 es láván 0V-ot mérek ami azt jelenti ha jól tudom, hogy készenléti állapotban van.
A végfok csere után kimenetein nincs fesz a 14 es láb kivételével minden jónak tűnik.
Ha berakom az IC/t akkor is ez a helyzet.
Tápok rendben, az IC lábain mérem a bemenő jeleket ha adok rá.
A 14 es láb feszültségét egy tranzisztor húzza le földre. A tranzisztor jó. Bázisán 0,66V.
A panelen nem lehet látni mi mivel van összekötve csak pár alkatrészt.
Ha valaki találkozott már ezzel a csodával, vagy van ötlete esetleg rajza azt megköszönném.
Üdv.:
Gy
