A tárgyban nevezett projectorral volna némi probléma.
Az LCD panelek le lettek szerelve tisztítás céljából.
Igaz a csavarjai sima kúpos csavarok, tehát, nem szolgálnak pozícionálásra,
de sajnos így is elmozdultak a panelek egymáshoz képest.
Van esetleg valakinek tippje, hogyan lehetne visszaállítani,
hogy együtt fussanak a színek?
Üdv,
KN
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Szevasztok
Ma behoztak egy inverteres heggesztőt a munkába,lekaptam a tetejét,egy elekrolit kifujt,4 db FGH40N60 rövid,pontosan nemtudom most a nevét,de valami 250 re végződik,állitólag generátorról használták ami sokat adott.
Mivel lehet hejettesiteni,mert a HQ nál csak diódásat ad a kereső,illetve menyibe kerül ennek darabja,ha megtudnátok mondani.
Adott egy tárgybeli GPS, aminek igen érdekes hibája van.
IGO8 fut rajta hibátlanul, de a műhold vétellel gond van. 10-20 perc alatt talál megfelelő mennyiségű műholdat, amiből adatokat tud kiírni.
DE: ezek az adatok (mozgatás nélkül) állandóan változnak, pld. klf. sebességet jelez, változik a magasság, sőt még változnak a koordináták utólsó számjegyei is. Egyedül az idő tűnik valós "változásúnak".
Megmozdítás nélkül pld. elveszti a GPS vételt, majd közli, hogy letértél az útvonalról.
Aztán újabb 5-10 perc, mire visszaáll a műholvétel. Aztán kezdi ugyanezt előről.
Port:5, sebesség: 57600, többször is újrakerestetve a GPS vevőt.
Így éppen a funkciójának megfelelően nem lehet használni.
Mi lehet a gond? Hardver, szoftver?
Üdv: Sándor
