Hello,
I have this LCD TV which has a very white screen, the picture is visible. I could not find any fault on the CCFL Lamp inverter and was suspecting the T-Con panel of failure. The T-con panel is integrated in the control board. What i did is using "freeze it" cold spray i sprayed one of the IC's and it cured the fault. Perhaps the IC needs to be replaced. The part number is AS15-G. This component is not available for purchase in south africa and i would need to import it from china. This part is a LCD voltage buffer.
Regards
Angelos
Sziasztok a fenti tv-hez keresnék nand flash mentést.
A flash:H27U4G8F2DTR
Alaplap: rsag7.820.5001/roh
Jó napot mindenkinek!
Segítségre lenne szükségem.
Hundai TF 2911 LEU. HISENSE-UOC belső talán.
Lenne ez a TV aminek nincs hangja csak zúg.AV-n minden rendben.
A menüben hiába váltom át a hangnormát nem reagál rá. Szerviz menübe be tudok lépni.
Proci TDA 9363
Minden segítséget köszönök szépen.
Üdvözlettel:Réti István
U on C809 is just 370V and I believe is not enought power to transfer in secondary circuit of power.
If I disconnect tcon or just display the tv dont go to stby.
Do you have diagram of powerboard HLL-4455W?
