Hello,
I have this LCD TV which has a very white screen, the picture is visible. I could not find any fault on the CCFL Lamp inverter and was suspecting the T-Con panel of failure. The T-con panel is integrated in the control board. What i did is using "freeze it" cold spray i sprayed one of the IC's and it cured the fault. Perhaps the IC needs to be replaced. The part number is AS15-G. This component is not available for purchase in south africa and i would need to import it from china. This part is a LCD voltage buffer.
Regards
Angelos
Hi
got the red flashing standby light,2 blinks
tried power off,with power button hols,and reboot,but no luck.
I guess board has fault,not sure where to start on checking board for fault
any help appreciated
ta
Kedves kollégák!
Fent nevezett TV T.MSD309.BA6S mainboard al van szerelve. Feltehetően SPI Flash tartalom hibás.
Esetleg,ha lenne valakinek tartalom igen jól jönne.A
http://remont-aud.net/dump/lcd_pdp_tv/blaupunkt/blaupunkt_32_126n_gb_5b_hbqkup_de_shassi_main_board_t_msd309_ba6s/380-1-0-44560
orosz oldalon van fent,hasonló main hoz de onnan nem tudok letölteni.
üdv.
A címben említett tv ki írja a logót majd újra indul és ezt ismétli folyamatosan. Flash hibára gyanakszom, ezért keresnék mentést hozzá 25q16 spi flash lakozik benne. RSGA7.820.50001 mainbord.
Válaszokat köszönöm előre is.
