HOWARD RADIO CO. HA-2 SCH
49.5 KB
Looking for similar howard manual?
HOWARD RADIO CO. HA-2 SCH service manual (1st page)
Preview of HOWARD RADIO CO. HA-2 SCH [1st page]
HOWARD RADIO CO. HA-2 SCH service manual (2nd page)
Preview of HOWARD RADIO CO. HA-2 SCH [2nd page]
    HOWARD RADIO CO. HA-2 HA2 HA
repair sony amplifier str-de254
Want to share: Have downloaded the schematics from this forum to help repair the amplifier of a friend. Turned out that Sony decided to route the earth through the chassis, even the earth between the various supplies. When one takes the main board out of the chassis and switches the amp on, there are up to 20 volts difference between the eart (and hence reference) of the pre-amps and the main amps. Luckily the amp goes into protection but from a design point of view it is not nice to rely on screws and aluminum face plates to conduct up to 0.2 amps of current from one supply to another. What I did is solder wires to every eart point and connected them on the main board to make it stand alone and not rely on conducting current through the chassis anymore. Bad design, simple repair but took some digging in the schematics to find out what exactly was going on!
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Marantz CD 73 Hang Hiba
A barátom cd játékosa került hozzám nemrég, a sztori úgy indult hogy egyszer csak elhallgatott és se kép se hang, ennek 5 éve most elhozta hogy kukkolja már bele mi lehet a nyűgje, első bizti csere mivel ki volt égve, aztán ráköt a hifire és csak ilyen sercegéses zúgás tör elő belőle, cd bele olvas mindent, de a zene mellé párosul ez a búgó zúgó hang mintha test hiánya lenne de ezt átnéztem és minden rendben, ötleteket szivesen fogadok. Egy kis videó arról hogy mi a hiba:
PANASONIC SA-AK210 HIFI torony javítása
Sziasztok!A fenn említett hifi-menet közben kikapcsol(csak a CD-t használom)-egyáltalán nem lehet bekapcsolni-híbákkal küzd.Kérem tanult kollégáim sagítségét!Köszönöm.Jano
