HR-S5955 VCR
TV - EPROM
Type: (E2P)
2.1 KB
EPROM
Looking for similar hr manual?
    HRS-5955 HRS5955 VCR HRS 5955 HR S5955 HR-S5955
HR7840=FCM2012E13 nagyfesztrafó melyik Samsung chassiba való ?
Van itt egy kinai BESTWELL CRT TV amiben BSC25-N0842 átütött (CY-PH1415TOP chassis)
Van nekem egy HR7840 uj trafóm ami fizikailag hasonlit, de a labsorrend nem ugyanaz, de nem tudom melyik Samsung SM szedjem le hogy a DC voltokat összehasonlitsam hogy átkötözgessem,
BSC25-N0842=BSC25-N0402=BSC24-N0402=BSC25-N0453=BSC25-N0887=BSC25-N0439
ZTFM77020A - HR80252 sorkimenőt kerestem, már tárgytalan.
Szevasztok! A fenti sorkimenőt keresném Panasonic TX-29PS20F/P TV-ben található. Köszönöm! norty
JVC AV-21FMG4G Chassis SCW-1362A blinks continuously after three failing power on attempts
JVC AV-21FMG4G Chassis SCW-1362A CRT TV blinks continuously after three failing power on attempts.
According to the customer, the upper portion of the screen started shrinking with horizontal lines, then ended with a single thin horizontal line.
This suspects the vertical drive section to be problematic. No vertical output though vertical in put is OK. After conducting an ESR check for capacitors in the vertical section, C428 (100uF 35V), connecting VCC1 with Pump-up pin # 3 of the IC, it measured 1200pF. It was replaced but still no vertical output. So changed the vertical IC401 (TDA78040), and the output appeared, but still blinks after three failing start-ups. I, m suspecting the corrupt EEPROM data.
CPU: TDA11010H / N1D00
EEPROM: 24C16A
Any one with EEPROM dump for this model or any help please?
HR 1NPC 7559-00 helyettesítője
Szevasztok ennek a fentebb leirt trafónak kellene a hejettesitője,ha tudnátok benne segiteni.
