Given:
Victor TT-71, neon lamp does not light, speed is lower than normal. This is subsequent some short circuit the owner does inside the device. No further details.
I found out the VICTOR QL7 have the same motor driver amd I downloaded the service manual that I attached here in case this manual is not already uploaded.
Looking at the diagrams I found out that at TP3 (same with pin5 of IC803) instead if that rectangular signal, I have nothing but 5VDC and a negative or positive short spike whenever I'm starting or stopping the motor and
Under the circumstances I suspect IC803 is defective. The bad thing, IC803 is NPC SC8043. Also I wonder if the crystal is fine (except that I wonder what can be wrong with a crystal after some short circuit).
Does anybody have any more suggestion?
Also, where can NPC SC4043 be sourced? Also, a crystal 9.054MHz?
Thanks in advance,
Corneliu
Hi,
If anyone knows if i can use a similar service manual ? i can't find the right document for my amplifier...
thaks
petiot
best wishes
Üdv mindenkinek ! Keresem a fent nevezett erősítő rajzát . / jvc ax-r562 / . Előre is köszönöm !
Sziasztok!!
Van valakine rajza ?
nem is tudom honnan kezdjem,nehezebb javitani mint egy TV-et,STBy nem mukodik,a digital gombok :TUNER,AUX,CD,CASETOFON,le van blokalva, csak a CD-en van kigyulva a piros led.A CD-rom eject gombja mukodik,a casetofon mindegyik gombja mukodik azok is digitalisak.
HANG NINCS.
koszonom
