Given:
Victor TT-71, neon lamp does not light, speed is lower than normal. This is subsequent some short circuit the owner does inside the device. No further details.
I found out the VICTOR QL7 have the same motor driver amd I downloaded the service manual that I attached here in case this manual is not already uploaded.
Looking at the diagrams I found out that at TP3 (same with pin5 of IC803) instead if that rectangular signal, I have nothing but 5VDC and a negative or positive short spike whenever I'm starting or stopping the motor and
Under the circumstances I suspect IC803 is defective. The bad thing, IC803 is NPC SC8043. Also I wonder if the crystal is fine (except that I wonder what can be wrong with a crystal after some short circuit).
Does anybody have any more suggestion?
Also, where can NPC SC4043 be sourced? Also, a crystal 9.054MHz?
Thanks in advance,
Corneliu
Adott egy JVC RV-NB52 bömbölde. Nincs benne a laser a CD-ben. Valaki járt benne.
Nem tudja valaki, mi való bele gyárilag?
A fent említett hifi, most már működik, csak a CD rész nem indul, mert ha megnyomom az open gombot azt írja a kijelző hogy LOCKED, mi a fene lehet vele, meg forgatja a lemeztartót, fejet is megemeli. Segítségeteket előre is köszi!
Üdv mindenkinek:
Keresném ennek a kb 25 éves JVC toronynak a rajzát, főként a tuner résznek.
Feliratok: tuner PC-T5L
erősítő PC-A5L
magnó PC-D5L
előre is kösz,Bálint
