Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
szervusztok mesterek
...a Kenwood GX-401EF2 cd,cassette receiver bekotesevel kapcsolatban kernek tanacsot,...tehat a 12v,hangszorok hozzakapcsolasa,
a gazdija sem tudta...es nemcsak toltore kapcsolta,hanem a polaritast is folcserelte
Üdv mindenkinek!!
Adott egy suzuki vagoner és egy kenvud autósrádió,a rádió tökéletesen működik ha áll a motor, de ha be indítom az autót a rádió hangja neki áll szaggatni,nem recseg hanem ki ki hagy.Ha az autó be melegszik ez a folyamat szite teljesen meg szűnik.A rádiót meg tápláltam közvetlenül az aksiról-- semmit nem változik a dolog. A dolog érdekessége, hogy szinte csak gáz adáskor jelentkezik ez a jelenség, de jellemzően inkább csak menetközbeni--gyorsítási alkalomkor, ha áll az autó és úgy pörgetem fel a motort akkor szinte nem is mutatkozi a jelenség.
Ha valakinek van valami ötlete, próbáltam a rá olvasást a szemmel verést ,.... de semmi nem változott.
Üdv Sallaan1
Hello Mindekinek! Törötten kaptam ezt az erősítőt és szerettem volna direktben járatni a végfokokat. Szóval csak a végpanel és a trafó maradt meg. A gond az hogy erősen sistereg mintha összeszedne nem kis zajt. Kötöttem már így végeket de ez kifogott rajtam. Letesteltem amit kell, minden feszültség érték megegyezik a manualban lévővel. Aki tapasztalt már ilyet kérem ossza meg velem hogyan oldotta meg. Előre is köszönöm.
