I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Adott eme szerkezet:
http://kepfeltoltes.hu/view/110424/video_www.kepfeltoltes.hu_.jpg
Mint láthatjátok hiányzik a komplett mechanika :( A kazettafészek van csak meg plusz az elektronika.
Érdekel belőle valakit valami? Ha nem akkor kuka, elektronikából kiszedem ami kell aztán kész.
Most már haladok a dolgokkal, van még sok video, remélem tudok majd segíteni valakinek alkatrésszel mostmár videókhoz is :)
Pityesz
Adott a címben szereplő DVD lejátszó.A hibája egyszer be lehet kapcsolni, ekkor működik rendesen,ha készenlétre kapcsolom a készenléti led pirosra vált,de a logó képet nem tünteti el a monitorról,ha áramtalanítok újra működik a következő készenlétig.Mi lehet a baja?RAJZOT NEM TALÁLTAM!A tápegység ic, ta1319ap,csinálhat-e ilyet?
sziasztok.
lenne egy ilyen szépségem a tápot már megcsináltam,a katettát beveszi,a kijelző működik csak ha elindítom a lejátszást elindul minden ahogy kell.forog a fej, felfűz ,elindul a csévélés kép nincs majd két másodperc mulva megáll a mechanika ebben az állapotában.stop gomb megnyomása után lefűz.tekerni is csak két másodpercig hajlandó.minden megállás után kiírja az F1-et.pedig szerintem a mechanika jól van összerakva. a MODE SW-et is megtakarítottam de nem változott semmi.tud valaki segíteni.(ugyanaz a mechanika mint a vs 500 csak van a mode sw felett egy kis csévélő motor)
van még egy vs380-as Grundigom. valaki megmondaná,hogy mi az F9-es hiba.
