KENWOOD DVR-6100 6100K SM
VIDEO-DVD - SERVICE MANUAL
4.3 MB
KENWOOD DVR-6100 6100K SM service manual (1st page)
Preview of KENWOOD DVR-6100 6100K SM [1st page]
KENWOOD DVR-6100 6100K SM service manual (2nd page)
Preview of KENWOOD DVR-6100 6100K SM [2nd page]
    KENWOOD DVR-6100 DVR6100 6100K DVR 6100
THOMSON video
Sziasztok. Van egy Thomson VPH6520 videomagnóm, az rf egysége kivan kapcsolva.Valaki nem tudja hogy kell vissza kapcsolni? sajnos nincs meg a használati útmutatója.A menüjébe nincs kapcsolási lehetőség. Úgy emlékszem hogy készüléken valamilyen gomb kombinációval lehet az rf egységet használni.
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
AIWA HV-FX3800 VHS videó felvevő több éves pihenő után a kazetta fészket nem emeli ki.
Tisztelt Szakik! Segítséget szeretnék kérni Tőletek a témában említett videó felvevő javításához. Sok éve pihenő videófelvevő készülékkel a családi felvételek digitalizására szántam el magam, de mindjárt az elején probléma adódott a szalag befűzés után a lejátszás nem indult, a kazettafészek félúton leállt. Szétszedtem, az idler görgőt meghajtó szíjat cseréltem, de úgy tűnik ennyivel nem úszom meg, a görgőt is cserélnem kellene, de nem találtam a neten a készülék alkatrész listáját, illetve azt sem tudom, hol lehet még alkatrészt szerezni, rendelni az ilyen öreg masinákhoz. A segítségeteket előre is köszönöm. Üdvözlettel: Sándor
Philips VR453 nem forog a fejmotor
Sziasztok! Most került hozzám ez a készülék, hogy nézem át mielőtt még használnák. Berakva a kazettát nem forog a fejmotorja, szétszedve találtam meg a N15-ös biztit ami a fejmotor 12V-át védi, meg volt szakadva, de csere után sem megy. A motoron ott a 12V, ha elindítom a servo ic-ről kap még 1.5V feszt az egyik lábon. A kérdésem hogy el lehet-e indítani a fejmotort külsőleg, vagy motor cserés lesz a gép?
