Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Üdv mindenkinek.
Van egy ilyen Kenwood erőlködöm.Keresgéltem itt,és láttam,hogy másnak is produkálta ugyanazt,mint nekem.Nevezetesen azt,hogy készenlétről ha bekapcsolom akkor egy pillanatra bekapcsol majd ki,és villog a készenlét ledje addig míg meg nem nyomom a készenlét gombját.Utána folyamatosan világít.Ha megint megnyomom kezdődik az egész elölről.
A megoldás nála az egyik (STK 443-070) végfok ic volt.Tulajdonképpen nálam is ez volt a hunyó.Viszont míg a másik emberkének megjavult ennyitől,nekem nem.
Összehasonlítottam az új és a készülékből kiszedett stk-t és kiderűlt,hogy az 1-es és a 7-es láb rövidzárba van.Máshogy kifejezve,az egyes lábon lévő +65 V-ot kiküldte a kimenetre.Kicseréltem az ic-t de maradt minden ugyan az.Segítségeteket kérném,hogy mi szállhatott még benne el,ill az lenne még a kérdésem,hogy a benne lévő uCom ic (az egész lelke) kinyiffanhatott-e?
Köszönöm.
Üdv Mindenkinek!
Fennt nevezett készülékhez keresek beépítő keretet, illetve azt a keretet, ami a levehető előlapot körbefogja. Fotó mellékelve Segítséget köszönve: FEJO
Kérem segítségeteket, egy Kenwood KDC-W7041U típusú autórádió gyári kódjának megállapításához!
szériaszám:KE1487W0201154
Köszönettel:
remi
