Tisztelt Szakik!
Egy ismerősöm fordult hozzám ezzel a kéréssel, hogy milyen módon (módokon) lehet ezt itthon beüzemelni.
Kiindulási alap hogy a legegyszerűbben és a legolcsóbban.(meg persze legyen üzembiztos)
Ehhez kérnék tippeket.
Amerikai eredetű készülék, 120V 60Hz, rajza a itt a tanyán, 13 oldal a táp rész.
Köszönettel D A
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Üdvözletem mindenkinek,
a fent említett erősítövel nem tudok düllőre jutni. Ugyanis, a jobb csatornán kb -8V fezsültség van a kimeneten, persze a védelem nem kapcsolja a relét (még jó), a bal csatorna OK. Első pillantásra nem nézett ki komplikált esetnek viszont most beletörtem a fogamat. A kimenőtranzistorokat lekapcsoltam mindkét csatornán és csak az A osztály működik. Letöltöttem a KENWOOD KA 1100SD SM-et, de sajnos a kapcsolási rajz nagy mértékben eltér a KA 1100D-töl, úgyhogy jóformán használhatatlan. A TA7030 feszűltségerősítő hibrid IC-ket felcsréltem, a hiba maradt ugyanazon a csatornán. A bemenőfokozatban a FET inegrált differenciálokat is felcseréltem, de semmire nem jutottam vele. Minden tranzistort kivizsgáltam komponent teszterrel és hajszálegyformák a grafikák mindkét csatornán. Mivel nem tudok tovább lépni kapcsolási rajz nélkűl, a WANTED-be tettem, ha valakinek az 1100D kapcsolási rajza megvan, legyen szíves, töltse fel.
további sikeres munkát
Hozzám került javításra ez a készülék.
A hiba jelenség a következő: akár milyen forrást választok nincs hang a kimeneten.
Kivéve csak direct source vagy source, phone forrás az ami megy. Tape 1, Tape 2, CD, AUX stb teljesen néma.
A választó kapcsoló gyanítom hibásnak.
Szkóppal mértem jelet de valahogy el vesztem a mérendő jelet, s nem tudok ki igazodni már rajta.
Ezért kérdem tőletek hogy találkozott e valaki hasonló hibával, mert nem tudok rá jönni a hibára.
Lehet én bonyolítom túl a dolgot.
De szeretnék pontot tenni a dolognak a végére.
Kérem aki tud az osztja meg velem a tapasztalatát.
Előre is köszönöm!
Üdv Istvan78!
