Adott a cimben szereplő autórádió.
Keresztanyámék öreg kocsijában volt mióta megvették, és most akkucserénél szembesültek a kód problémával.(minden még a doboza is meg van, de szerencsésen kidobták minden papirját)
A lényeg, találtam az alaplapon egy 24c01 eepromot, rátöltöttem egy elvileg jó tartalmat, de nem fogadja el a kódot!
Addig bogarásztam, mig a tunerben is találtam egy szintén 24c01-est.
Létezik, hogy 2 helyen tárolja a kódot?
Esetleg nem az alaplapiban van hanem ebben??
Ha a tuneresben van, azt hogyan olvassam ki?
Köszi a segítséget4
atomka
Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Üdv! Sajnos már bontottan kaptam az erősítőt és szükségem lenne a tranzisztorok pontos típusára és pozíciójára Q1-Q18-ig. Minden megoldás érdekel. A kenwood_kr-910_sch_[ET] erősítőhöz van rajzom,de nem teljesen egyezik és elakadtam. Ha valaki tudna segíteni azt nagyon megköszönném.
Na ilyet még nem láttam: a processzor Protect bemenetén alapból L szintnek kellene lenni, üresen 1,5V körül van rajta és bekapcsoláskor azonnal a PROTECT jelenik meg a kijelzőn. Namost a védelmi áramkör aktivitása esetén H szintet produkál, viszont ha mesterségesen adok egy H szintet a proc. bemenetére (Q8 kollektora, szervízkönyv 25.oldal), az esetben hajlandó csak működni az erősítő ! :hmmm: Ilyenkor 4V-os H szint van a proc. 31-es lábán.
Megfordult a logika?
