Keresem a KT1060 tuner kapcsolási rajzát, kérem aki tud segítsen.
Üdvözlettel:
Feri
Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Because I did not found it and I was forced to buy, you get it for free!
https://mega.nz/#!RlpCxCRQ!zhVCwJnC3dDiYlJSmDqRMOVeLzL7soairMfFxsup61A
Adott egy kenwood krf-5070d típusú házimozi. Jelenség, hogy ha bekapcsolom, bejön a kijelző, és mikor a védelem kapcsolna, kikapcsol, és a stby led villog. Ha kétszer megnyomom a stby gombot, megint bekacsol, tölt, és újra le. A védelemre tippelnék, mert akkor kapcsol le, ha a védelem rákapcsolna a kimenetre. Sajnos az STKról nem találtam jó leírást, hogy mit kellene mérnem. A service manualba a 17-20as láb a kimenet, máshol meg a 9-11es láb. Ebbe kellene segítség, hogy mit mérjek, és milyen értékek lennének a jók.
