I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Áram alá helyezéskor már a PROTECT felirattal kezd, semmilyen gombnyomásra nem reagál, cd-t beveszi-kiadja de nem forgatja meg és teljesen néma.
Végfok-ic, cd-egység eltávolítása után a helyzet ua., a regulátor ic-nél /IC901 LV5680/ vannak eltérések tápfeszekben, 6-8 lábon fele feszültség van a rajzhoz képest, a 14-15-ön pedig 0v a 4,9 ill. 13,5v helyett, az alaptápok mint a 3,3-5-8,5-9v-ok megvannak.
Nem tudom hogy bekötési hiba után lett-e ilyen vagy menet közben, van-e ötlete valakinek hogy mi lehet a gond, a regulátor ic cseréje sem túl egyszerű próbára mert 4-5ezer körül van S-nél és nem egyértelműen néz ki hibásnak, panel teljesen ép, gyanúsnak tűnő alkatrészt nem találtam, köszi.
A fentnevezett rádiót nemrég hibásan kaptam.
A Tanyán található Kenwood KR-A47 rajz alapján,sikerült megjavítani,hiányzott a +14V.
A rajz nem pontosan ezé a rádióé, de az erősítő és a táp ugyan az.
Szépen szól az erősítő, és a rádió jó érzékenységű szerkezet.
Egyetlen hibája hogy kikapcsolás után, kb. egy óra hosszáig tartja meg a memóriába beállított frekvenciákat.
Mivel elemet vagy akkut sem a rajzon sem a rádióban nem találtam,kapacitását elveszített kondenzátorra gondolok,de nem tudom melyik lehet.
Ebben kérném hozzáértők segítségét.
Előre is köszönöm.
Laci.
A fenti minihifi nem kapcsol be, áramingadozás után.
A tápban 3 dióda zárlatos volt két bizti kiment, ezeket megcsináltam, de még mindig nincs életjel.
Ha vkinek volna rajza azt megköszönném, ha elküldené.
UI. tudom rajzot nem itt keresünk, de a helyén már próbáltam eredménytelenül, megpróbálom itt is hátha több siker lesz a vége.
Nincs senkinek tippje?
